All Things Mk5 => How to Guides / Troubleshooting => Topic started by: garrardrj on February 02, 2012, 09:05:17 pm
Title: Leather Seat dented by Seat belt
Post by: garrardrj on February 02, 2012, 09:05:17 pm
When i have had the rear seat down with stuff loaded in the boot one of the rear seat belts (the metal bit) has been pointing down when i folded over the seat and it has pushed into the seat base causing a dent. This was 3 weeks ago and it is still pushed in quite alot. I have tried heating the leather squeezing it etc to try and get it back into shape without success. Any ideas how to sort it out ? Is there a nack ?
Title: Re: Leather Seat dented by Seat belt
Post by: Top Cat on February 02, 2012, 10:41:02 pm
Time.  :smiley:  plus maybe using that seat to get a bit of pressure on the dent from different angles.  :happy2:
Post by: rich83 on February 02, 2012, 11:17:54 pm
Sames happened on mine too.
Post by: Horatio on February 03, 2012, 02:35:50 pm
I had the same problem on my old bora. Used to use it for work. As the parcel shelf cannot be removed I was always putting the back seats down which caused a fair bit of dentage on the leather. I used to spend at least an hour or two every weekend trying to get these out. One method I found that partially worked was using a rolling pin with a bit of heat.  :rolleye: I think if you can get some heat on the area your working on it helps the sponge to rise/plump up. It was always worse in the winter too.  :rolleye: :rolleye: :rolleye:
Post by: uk_stu on February 06, 2012, 09:21:00 am
I get these issues quite a lot at my work (building Rolls-Royces) and the simplest way of getting them out is with a hairdryer/heat gun. Gently heat the leather and manipulate it with your hands to shrink the dent out.
Hope this helps!
