All Things Mk5 => Mk5 General Area => Topic started by: Rustybear on February 04, 2012, 05:26:32 pm
Title: OEM phone kit
Post by: Rustybear on February 04, 2012, 05:26:32 pm
My car has a Nokia 6100 phone kit fitted to the dash which goes through the OEM sat nab etc.
I have an iPhone 4, for the part number and price for an iPhone cradle to replace the old Nokia one but fedora anyone know if it's a simply in lip the Nokia one and clip the iPhone on or will wires have to changed etc. I asked the local vw parts person how to fit it who didnt know. Any info welcomed as I may have buy an old 6100 to just use in the car otherwise which ain't ideal.
Title: Re: OEM phone kit
Post by: apples12 on February 04, 2012, 07:36:17 pm
it'd be much cheaper for you to replace the bluetooth kit with a normal bluetooth one like a nokia ck-7w, that too will go through the sat-nav and very simple to install because you already have everything 'plumbed in'
do you know which 'box' you have?
Post by: Rustybear on February 04, 2012, 10:37:58 pm
Thanks. Don't know what box it is, can you clarify what the box is??
Post by: apples12 on February 05, 2012, 07:40:06 am
hi
well, the handsfree kits made up of a few 'components'
1) microphone
2) cradle / interface to the handset
3) control box
4) wiring to the headunit - the mk5 golf / quadlock headunits are wicked in the sense that they have a telephone input built into them! no need for any fancy wiring, no need for an external 'mute' box, no nothing extra. Where you would connect the 'speaker' in an ordinary handsfree kit, you simply connect it to the L/R connector on the radio connector as it is labelled on the back of the radio - very very easy to do, the handsfree kit comes with the plug to do this usually.
the 'box' i'm referring to is the control box, because the wiring is usually quite standard if its a nokia handsfree kit, so you could in theory just swap the control box for a bluetooth one and that should be that!
