All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: Johnny_tro on February 05, 2012, 10:12:57 pm
Title: Heated Seats
Post by: Johnny_tro on February 05, 2012, 10:12:57 pm
I assume the heater seats are just a flat/thin pad that sits between the foam and the fabric?
is it a one piece? or two? i.e base and back?
Do you think its possible to................
take the heated seat loom and switch......and add this into the current loom (for the fronts) and have heated rears to with independent control?
Title: Re: Heated Seats
Post by: Phil Miller on February 05, 2012, 10:14:35 pm
Im not sure i have been told the element is part of the fabric not a mat (as they use to be) but there may be a way round it
Post by: Johnny_tro on February 05, 2012, 10:17:46 pm
part of the actual trim colour (attached to the leather or cloth) ?
Post by: Weston on February 05, 2012, 10:19:40 pm
I expect it'd be a lot of work to do. Do you regularly have passengers?
Post by: Johnny_tro on February 05, 2012, 10:28:19 pm
I do buddy yea...kids
The outside of my car used to be my concern. Now it all interior........where we spend a lot of our time.
I thought - it maybe a simple-ish job (on paper anyway)
2 x heated pads
2 x looms
2 x switches
and someway of linking it into the current loom
Post by: Teutonic_Tamer on February 05, 2012, 10:50:34 pm
Sports seats with bolsters (ie, the standard GTI seats) have four heating pads per seat: two big square ones for the squab and the backrest, and two long thin ones for the lower bolsters.  The standard seats found in poverty spec Golfs with heating have just the two main pads.  The controller seems to be the same for either type.
HTH
Post by: Johnny_tro on February 05, 2012, 11:10:05 pm
OK - so the base pads - have wings so to speak for the edges.....
Any idea if they are independent? or fixed to the seats covers?
Post by: Teutonic_Tamer on February 05, 2012, 11:19:52 pm
Did you not read my previous post?  :mad:
The GTI sports seat (with bolsters - or wings as you call them) has four separate pads (completely separate).  The pad in the seat base has the main fly lead with the appropriate number of connectors to feed the back, and if needed, the wings.  The backrest element looks universal, the seat base seems to differ dependent on sports or standard seats (along with its fly lead).
The control unit (one per seat) clips under the seat on the metal frame - so you'd need to find an appropriate void somewhere in the rear - but keep it away from the rear side crash sensors.
You could probably mount some switches in the rear end of the centre console - like they do on Howdies.
Post by: Johnny_tro on February 05, 2012, 11:31:33 pm
 :ashamed: Sorry..............
Using ALL VW bits - pads, wiring loom, controllers etc - is going to be expensive.
Also going VW (using the controllers) do you think you would get any coding issues?
Think it would be easier (cost effective) just to use a universal kit of some sort?
Post by: Teutonic_Tamer on February 05, 2012, 11:41:16 pm
Which type do you want me to look up - with wings or without?
Pass.  I'm not even sure if the front seats are coded . . .
Best let one of the forum sparkies answer that.  :wink:
I dunno - are they actually available?
If they are, just make sure they are appropriately regulated (CE, and ideally TUV) - you wont want to be toasting their little ar$es!!!!
Post by: Johnny_tro on February 05, 2012, 11:47:12 pm
Needed.....
2 x base (without wings) bag don't really have the edges
2 x rears
2 x controllers
2 x switches
I was googling and found this..................what you think??
http://www.ebay.co.uk/itm/VW-Golf-Bora-Passat-Retrofit-Heated-Seats-Kit-Looms-/370140859960?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item562e1d4e38
or cheaper kits
http://www.ebay.co.uk/itm/Universal-Heated-Seat-retrofit-kit-2-seats-4-x-Carbon-Fibre-heating-elements-/400245051113?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d3076cee9
Nothing about TUV on the adds
Post by: Phil Miller on February 06, 2012, 12:28:37 am
having looked at both kits i think the kit for the mk4 is the one id go for, altho you will prob struggle to intergrate this into the mk5 loom, you could always run it seperate if you can, that would avoid coding/canbus issues
Post by: Teutonic_Tamer on February 06, 2012, 09:56:50 am
Needed.....
All right - lets' see what I can rustle up . . . prices (for qty1) are a guide (not updated my ETKA for ages) + vat.  They are on ETKA illustration 963-00, if you want to pop in the stealer and have a look.
1K0 963 555 G - £69.40
2 x rears
1K0 963 557 R - £69.40
2 x controllers
7L0 959 772 D - £49.55
2 x switches
I can't find these . . . maybe the Pissrat Passat has separate switches . . .
If you can get it to fit - then it will be fine - it is a genuine VW part, so will be appropriately tested/approved.
Doncha just love the Haynes-esque instructions though - "with the ignition switched on or the engine running, the seats should heat up when the seat heating is switched on" . . .  yer don't say!!!!! :notworthy:  :rolleye: :evilgrin:
or cheaper kits
That looks OK - though I'm not a sparkie.  :wink:
I would say those kinda things are important if say you were looking at some Chinese imports from some dodgy-looking trader.  The two e-bay links above are both seemingly reputable.
@ Phil - the 'embedded' elements seem to be only with cloth covered seats (pr N4C), all the others seem to be separate elements.  :wink:
Post by: Johnny_tro on February 06, 2012, 09:48:12 pm
Thanks for this guys.
The prices you have listed these are all for 'ONE' item?
The one kit of Ebay (VW ones) seller says its not marked as approved (safety) but as all bits are genuine VW they will be tested anyway.
Right - anyone fancing doing some wiring lol
Post by: Teutonic_Tamer on February 06, 2012, 11:35:39 pm
Read the top line of reply #12 - YES!
The genuine VW jobbies will be just fine.  :pomppomp:
Moi . . . er non!
