All Things Mk5 => Modifications & Technical Area => Cosmetic/Interior Modifications => Topic started by: d.mellor on February 08, 2012, 10:17:38 pm
Title: Will these fit?
Post by: d.mellor on February 08, 2012, 10:17:38 pm
As above. Looking to buy some new wheels
Fronts are, 17" 8j et 42
Rears are, 17" 9j et 42
Will these fit mk5 golf?
Title: Re: Will these fit?
Post by: vRS_Pagey on February 09, 2012, 04:49:20 pm
Providing the PCD is 112 and the centre bore is 57.1 or higher (you can fit spigot rings) then maybe, to give you an idea of the difference, the 8j wheel will extend 15mm further and the 9j 28mm than OE, so they could rub, especially the 9j.....
Post by: mvb12 on February 12, 2012, 11:39:28 am
imo 17" are too small, 18" should be standard to purchase as upgrade but each to their own i guess?
Post by: Syrag64 on February 12, 2012, 01:23:35 pm
IMHO even 18" looks a little small, I'm looking to get a similar size but in 19" but after looking at loads of wheels i'm thinking of going 19" 8j et 45 on the front and 19" 9j et 45 on the rear (or maybe even 19" 8.5j et 45 - if a wheel exists?)
You could also go for a stretched rear tyre to maybe minimise the rubbing?  - I could of course be wrong on that so if i am someone please correct me  :driver:
