		All Things Mk5 => Mk5 General Area => Topic started by: edition_30 on February 13, 2012, 06:26:47 pm
				I received my vw Bluetooth kit form a seller on eBay but if you look at the picture one of the wires is cut.
Is this the antenna & should it be like this?
Also, should I have received anything to mount the unit under the driver’s seat?
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi11.photobucket.com%2Falbums%2Fa183%2Fdbitalia%2FIMG_0301.jpg&hash=8aa3fb3aa888b75483851313c06395fa0d8ffb03)
				Not sure on the antenna as mine was alot longer and had a large plastic part on the end, i do know some are shorter but havent seen one,  as for the under seat fixings did he state in the advert it had the under seat housing ?, that was really up to you to check i guess, is it a trader ?, do you have a link ?
				no it was a private sale off e bay. no mention of the under seat fixings, i just thought it would come with the kit as standard.
can the fixing be purchased from vw along with a new antenna?
				what phone kit did you buy?
				Link to the original eBay listing?
				http://www.ebay.co.uk/itm/270781829725?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
				That's a real bodge for the bluetooth aerial, it should look like this: -
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww.carsystems.pl%2Fimg%2Fproducts%2F31%2F1_max.jpg&hash=31ed386d0b5462321271b972f18bea13552b6469)
				Looks very odd.  They it as Bluetooth Antenna 6Q0 035 576 H
Looks to me like you need a Bluetooth Antenna -
8P0 035 503 E - Bluetooth Antenna
Pictures on my website -
http://octavia-vrs.com/cms/content/integrated-bluetooth
				Hang On a minute, it says NEW in listing. That aint new having been hacked like that. Get your money back mate
				I'm not sure it's a hacked off wire, although it sort of looks that way, I think it's a BT Antenna - Possibly DIY.
That's my thinking too  :happy2:
				Thought so...
I will order one along with the following parts to mount:
1Z0 971 813 62U - Covering Black
N909 460 01 - Expanding Nut x2
N908 170 03 - Torx Screw x2
6U0 819 055 - Clip x2
Is there anything else i need for the install?
Also luck with the mdi Steve, i think carsystems.pl has some, this the correct kit?
http://www.carsystems.pl/vw-media-in-box-mdi-kit-ipod-adapter-retrofit,id192.html
				Nope no luck, so the car system's one is probably your best bet and the one in your post is the correct one  :happy2:
				Thanks mate.. will get it ordered, do I need anything else & will this charge my iphone?
				It would break my heart to have to give those twa@ts any money.  Have you thought about a genuine kit??
There are two options but the better one for glovebox IMHO is 5N0 057 342 at about £150 ish from your local dealer
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fh11.abload.de%2Fimg%2F5n0057342_xmbo.jpg&hash=85fd1cbef85fa9cf73b6e57e655fc7342ed69821)
				is car systems not original then?
Also i want armrest version rather than glove box, is there any difference?
				The car systems module is genuine but the loom will be aftermarket.
				VW offer an OEM kit as well for the arm rest IIRC.  The one I listed would work in the armrest but would give you just a trailing cable to put wherever you want rather than the slot type.
Car systems is a made up kit.  If you have the BT loom with the quad lock adaptor and then the car systems adaptor it will be very bulky.
				is there any difference in quality/ audio quality etc with the after market looms?
to be honest i dont really need the slot as my iphoine is in a case and if i could have a cable from the armrest area i would be happy. I do want it to look neat tho, no manual cut-outs etc..
Are there different versions of the mdi that provide different functionality?
				In which case I would suggest the kit I mentioned above with an extension cable 000 051 447 which will allow you enough slack to have it exit where ever you wish in the centre console area.
				Thanks stu..
If i wanted the armrest version as im thinking it may be a nicer fit??  could i use the same extension cable too?
				Yes the extension cable is just that so it will work for both types.
				Do you know the part number for the armrest kit?
				5N0 035 341E is the arm rest kit but I'm not sure if it includes a wiring loom.  The other kit I know does as I've used them.
				VW should be able to tell me?
If it does not come with the loom then can this be purchased separately?
				Nice well made harness - http://www.kufatec.de/shop/product_info.php/info/p1927_c26_VW-MEDIA-IN--MDI-Interface---Harness---universal.html
Ext cable discussed above - http://www.kufatec.de/shop/product_info.php/info/p1428_c26_Audi-AMI--VW-MDI-Extension.html
				Thanks again stu
I will speak with vw tomorrow and then go from there...
				If you order from Kufatec then bung this in too -
http://www.kufatec.de/shop/product_info.php/info/p1872_c284_Bluetooth-antenna---Audi---VW.html
Sorry to hijack, but can I have the glovebox mdi ipod lead with a 6cd changer  or does it share same quadlock?
				I think they can co-exist.
				Thanks vrstu
will do.. :happy2:
Do kufatec sell teh armrest mdi too?
				Yes they sell the armrest kit.
				http://www.kufatec.de/shop/product_info.php/info/p1131_c26_VW-MEDIA-IN-MDI-Interface---Retrofit--.html
				cool.. i did see that but was not sure if it would fit the armrest.
Do you think its more expensive than vw
				also with the mdi kit can i search my iphone via artist/ track title?
				if you live in UK purchase the kit from Kufastec.de as its cheaper than the UK site!  :happy2:
				decided i am going to order the lot from kufatec..
in terms of the extension cable, from locking at the picture on the kufatec site the cable appears not to have the correct end connection for an iphone.
If installing the mdi kit in the centre console do i need the extension lead,
				boldsport sell them aswell heres a link
http://www.bold-sport.com/store/index.php?route=product/product&path=35&product_id=90
or this 1
http://www.ebay.co.uk/itm/VW-MEDIA-IN-INTERFACE-MDI-iPOD-USB-RNS-510-RETROFIT-KIT-inc-WIRING-USB-iPOD-LEAD-/270907709065?pt=UK_In_Car_Technology&hash=item3f135b9689
				I thought it was one or the other,it definatly was on a MK5 with the basic ipod kit. I wasnt aware it was any different now but i may be wrong.
You still need the adaptor to go on the extension cable that you would have used without it.
				Went to pick up the Mdi from vw yesterday. £240 with no loom!
They also wanted £120 for the loom. Decided not to take it. Have looked on eBay as there are a few but I'm not sure as I want an original loom.
Does anybody know of the loom kufatec supply with their Mdi kit is oem?
Thabks
				Which part number?
This one, 5N0 057 342, is a kit and includes the wiring and everything you need but is the discrete version.
Kufatec make their own looms.
				I'd be interested in the part number of the loom for £120,i wasnt aware VW did it seperate as i have looked before.
Which part number?
When you say discrete, glovebox fitment?
Do you think I would be able to purchase the armrest caddy on its own then use the kit you mention?
				No because the loom wouldn't be long enough.
				What should I do nxt stu as I'm lost for ideas. If possible I do want all oem but if not possible then it's going to be easy to order the lot from kufatec. Would you say there is a difference between the kufatec kit & car systems?
What's the difference with their loons compared to vw?
				I think you are somewhat confusing yourself and making it more complicated than it needs to be. 2 options, with the cradle/dock setup or with the discrete 'flying lead' where the install is behind the glove box.
For the cradle type you need the longer loom to get from the radio to the armrest area. (I think you can fit a cradle to the glovebox but you need to have the right glovebox, previously with CD changer etc).
These can be bought from various sources with non OEM looms. The OEM loom is as you found out expensive.
For the discrete type the controller mounts behind the dash out of the way With just the part you need to plug into the device laying in the glovebox. What you can do is get an extension lead for this type that plugs into the controller and then the device lead (iPod / USB etc) plugs into that. You can then run that to pretty much anywhere it will stretch.
Non OEM looms tend to use quad lock male/female combo to achieve plug and play. I'm not a fan of these as they are big and bulky. One member here bricked his RNS510 with exactly one of the fitted with an MDI because the loom didn't connect CAN properly. The thread is massive if you ever come across it. He changed DVD drives and all sorts. He came to me for a ViM mod and I discovered the fault.
