All Things Mk5 => Mk5 General Area => Topic started by: nezquick on February 15, 2012, 05:47:31 pm
Heres my scan and results.
Sorry I am really new to this and trying to teach myself but I don't want to be messing around with codes and possibly upsetting my car before I drive to briston on friday.
So forgetting about the electric windows (they work fine and so does my footwell lights so can't quite work it out?!)
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: ----------- Mileage: 116810km/72582miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 HW:
Component: 2.0l R4/4V TFSI 00 0070
Revision: --H01--- Serial number: VWZ7Z0D1220341
Coding: 0403000318070060
Shop #: WSC 00607 210 71741
VCID: E3C12BBF5BC5
2 Faults Found:
000665 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 115422 km
Time Indication: 0
Date: 2000.00.00
Time: 13:37:28
Freeze Frame:
RPM: 3718 /min
Load: 84.3 %
Speed: 52.0 km/h
Temperature: 87.0°C
Temperature: 22.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 14.224 V
000256 - Mass Air Flow Sensor (G70): Supply Voltage
P0100 - 004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 5.0°C
Temperature: 5.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.938 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0004738
Shop #: WSC 01279 785 00200
VCID: 3A7F36DB0CCF
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AB
Component: ClimatronicPQ35 066 0404
Shop #: WSC 00000 000 00000
VCID: 67D9BFAF2FFD
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001309029
Coding: E58D0F0600041800001400001400000000087F075C
VCID: 3A7F36DB0CCF
Part No: 1K2 955 119 B
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
Part No: 1K0 955 559 M
Component: RegenLichtSens 005 0605
Coding: 00218142
Shop #: WSC 00000
1 Fault Found:
00061 - Footwell Lights
012 - Electrical Fault in Circuit
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 C HW: 1K0 909 605 C
Component: 08 AIRBAG VW8 013 2100
Revision: 02013000 Serial number: 0033HD0316KN
Coding: 0012344
Shop #: WSC 01269 785 00200
VCID: 2C530083F69B
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 521 0050
Coding: 0000012
VCID: 356525E725D1
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K6 920 960 D
Component: KOMBIINSTRUMENT VDD 0812
Coding: 0003403
Shop #: WSC 00607 067 57207
VCID: 306B14F3DAB3
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104C02079E
Coding: 3D3F0340070003
VCID: 295DF997F969
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 0812
VCID: 306B14F3DAB3
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0148
Coding: 0000052
VCID: 306B14F3DAB3
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.12 1502
VCID: 316D11F7D1B9
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 81C802087F2D8505485FC69010
VCID: 7BF1F3DF4375
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Part No: 1K0 951 177
Component: Innenraumueberw.004 0101
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Component: Tuersteuergeraet 09 0154
Coding: 0000052
VCID: 316D11F7D1B9
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 L
Component: Radio BVX 012 0022
Coding: 0040402
VCID: 2F69178FC78D
1 Fault Found:
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 C
Component: Tuersteuergeraet 06 0213
Coding: 0000016
VCID: 306B14F3DAB3
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 C
Coding: 0000016
VCID: 316D11F7D1B9
1 Fault Found:
00935 - Electric Window Motor; Rear Right (V27)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
End ---------------------------------------------------------------------
Can someone explain to me what to do please?! THANK YOU! Should I just click the clear all faults button and hope for the best?!
Thanks so much in advance and please be nice, we have to learn from somewhere. Think of it as im the pupil and your the teacher :wink:
P.s I don't mean boffin in a rude way :signLOL:
Looks like you have a boost leak!
Also at some point the MAF has been disconnected.
I would start by looking at your Divertor Valve as thats the most common cause for this on TFSI's
Iv been discussing this with other people and swore iv had a boost leak for a while. millage is high so presume it has gone by now. should i just clear all codes and moniter the situation and whether they come back? Maf was discounnected three four days ago so explains that! Thanks for your help and response!!
I agree with Kalu, for the time and effort involved check the DV.
Ok, so far I have learnt the following:
000256 mass air flow sensor can simply be cleared as it was removed causing this fault.
Electric windows because I discounnected and changed my battery (same for radio) so just need to do the reset of all he way up all the way down, 2 secods, all the way up again and can clear codes,
ABS Brakes I am unsure about but may be from when I unplugged the MAF as it does turn traction control off and apparently the DTC memory - intermittent is more of clear job so will just clear that.
The footwell light is from the LED's im using but should not be a problem once cleared the codes although it may still through an error (not too bothered)
but the main one in like mentioned the boost pressure regulation as from what I've read leads me to think it is in fact a torn dv, I think I will stop at the garage tomurrow and ask him to take a look for me as he won't charge me anything to look and the weather isn't brilliant to be lying under a car.
The main question now is if I read the codes in the morning before work and then choose the clear codes function. Is it safe to clear the boost pressure regulation code or will it make it unsafe to drive. Also will it just through up again after driving and from what im looking at (and guessing) almost 30mph at 3718 rpm?
and how long will it take roughly so I know how much earlier to wake up before I go to work.
thanks in advanced!
You can clear the codes no problem..
:happy2: Ill do that in the morning then, any idea how long it could take?
To reset the windows you can also use the ignition key in the drivers door lock. Turn it fully to lock and count to 2, then turn it to unlock, hold it and all the windows will open. Again count to 2 then turn the other way, hold till all windows close and count to 2.
To clear codes? No time at all.
To check DV? 30 mins For a first time.
lovely I think ill do that then, can I do it using the key (where you make the windows go down with unlock and up with lock when you hold the buttons down) because then I don't have to do it outside I can do it from my front room in the warm :signLOL:
Lovely, Yeah I had a look the other day under the car anyway and could see it the one question I have is it easier to get to the bolt at the top from above?
tool wise im sorted to do it just want to know if theres any experienced tips, for example someone told me to leave the bonnet open makes things easier to see even from under the engine.
Attack it from underneath. To be honest you may as well get a new DV and fit it as the revised models are more reliable.
completely off topic but i have lost my genuine bag com lead :(
not happy
Also dont forget to check the pcv as that can bring on the P0299 fault code. I was plagued by this fault code a while ago and it turned out to be the stage 1 map. Since I had it updated the fault code has never appeared again.
Cheers, did my windows this morning before work but decided to wait until I get home tonight before cleaning them using vagcom and clearing all codes at the same time.
I did the check where you let the engine idle and it should go rough if the pcv is failing. Sound right? if not whats other ways to check? i think i read something somewhere that you need to remove the pcv valve and try and blow through it?
no map yet so can't be down to that. :sad1:
happy to see the leads doing its thing :happy2:
good luck with the fixes mate!
Thanks very much.
Ill recommend you anytime :wink:
