All Things Mk5 => Mk5 General Area => Topic started by: ED30_jase on February 15, 2012, 08:16:37 pm
Title: Should my engine sound like this....(video)
Post by: ED30_jase on February 15, 2012, 08:16:37 pm
Hey guys I know the tapping is the direct injection but whys the hissing to the left that sounds like misses Hubbard is biking by?
I've checked the DV and its a revision G? Is this any good? Also removed the dipstick and it ticked over lumpy?
Any help appreciated
Jase
Sent from my iPhone
Title: Re: Should my engine sound like this....(video)
Post by: ED30_jase on February 15, 2012, 08:18:31 pm
Sorry here's the video...
ttp://www.youtube.com/watch?v=xVGwNqOCcm0&feature=youtube_gdata_player
Sent from my iPhone
Post by: Saintsteve on February 15, 2012, 08:20:56 pm
Sent from my iPhone
Corrected...
Post by: Saintsteve on February 15, 2012, 08:22:18 pm
Campbelt tensioner mate..
Post by: ED30_jase on February 15, 2012, 08:27:56 pm
Oh so this is a normal noise? and nothing to worry about?
Cheers for the help guys! this forum is invaluable!  :happy2:
Post by: Saintsteve on February 15, 2012, 08:29:14 pm
Yes cold engine,  disappears when warmed up. Yes next Cam belt change, get the tensioner changed and that'll cure it.
Removing the dipstick will make it run lumpy, a faulty pcv causes lumpy idling , and if by pulling out the dipstick wouldn't make any difference   :wink:
Your just de stabilising crankcase pressure by removing the filler cap or pulling the dipstick, which will upset the manor in which the engine stabilises it's idle.
Post by: RENNTAG on February 15, 2012, 08:32:18 pm
Yep cambelt tension, mine did this before cambelt change. All good now.
Post by: ED30_jase on February 15, 2012, 08:36:08 pm
I see....Well that makes me feel better think I'll get it done now it's due in June anyway...thanks for this guys!  :happy2:
Post by: Saintsteve on February 15, 2012, 08:38:38 pm
No problem, oh and thankyou tab is your friend nudge nudge lol
Post by: ED30_jase on February 15, 2012, 08:45:33 pm
Oh yeah I always say thank you but forget that button will be getting pressed more often from now on!!  :happy2:
Post by: Tfsi_Mike on February 15, 2012, 08:45:56 pm
Mine sounded much like that @ 55k miles solved with new cambelt kit
have a noise at cold from same area now though 10k miles later. Will get a vid up.
Post by: ED30_jase on February 15, 2012, 09:46:56 pm
That's a bit soon really isn't it?  can it be adjusted without actually replacing it all to try and cure it?
there not the most attractive sounding engines are they  :grin:
Post by: Tamiyoman on February 15, 2012, 09:49:07 pm
I am glad someone answered this, as my own ED30 started doing this only this week, I kind of guessed it was possibly cambelt or a tensioner, its getting done in May anyway on its 4yr anniversary  :happy2:
Post by: Tfsi_Mike on February 15, 2012, 09:53:51 pm
I'm quite anal with servicing tbf.  If anything was being changed, fore it would have to be full cambelt kit again.
I'm not sure what the noise I'm getting now is I'll get a vid
Post by: dan930 on February 15, 2012, 09:54:12 pm
Mine sound like that too...is it a big job to do as my cambelt is not due for another 30k
Post by: Russ_leeds on February 15, 2012, 10:27:39 pm
my cambelt used to do it but no where near as bad as that and i got a new cambelt and water pump done f.o.c on warranty  :jumpmove:
Post by: Dsg steel on February 16, 2012, 12:24:39 am
Mines making same noise even tho I've changed cambelt kit and tensioner 20k ago.
Anyone with same problem?
Only happens when it cold
Billy
Post by: Horatio on February 16, 2012, 06:17:24 am
SNAP!
http://s166.photobucket.com/albums/u94/hansumbwunderful/?action=view&current=Video0020.mp4
Vid taken from inside the car as I was convinced it was a loose bolt. Mine has done this as well since purchased in August. Cambelt is due, just over 4 yoa on 28k.
Post by: andrewparker on February 16, 2012, 07:37:45 am
Mine needed doing at around 32k.
Post by: Saintsteve on February 16, 2012, 08:06:02 am
SNAP!
Try and do a sound clip outside on idle as that's difficult to make out its the same problem. Yours might be a blown pcv.
Post by: flyboy1976 on February 16, 2012, 01:07:58 pm
Yep I had that sound @19K.....warranty job at the time but I had x2 idlers, cambelt and tensioner inc waterpump all done at the same time....same as Steve said, did it from cold then shut up after a while.
Post by: Creatz on February 16, 2012, 02:46:48 pm
i made the same post last year  :signLOL:
i got the cam belt (it was nearly due)changed and now its silent  :happy2:
but nothing to worry about
Post by: andrewparker on February 16, 2012, 03:06:15 pm
I too have a cambelt video!
Post by: Tamiyoman on February 16, 2012, 04:35:06 pm
Same noise as mine altho mine is quieter than that, once warmed up its barely noticeable.
Post by: andrewparker on February 16, 2012, 06:07:59 pm
Yeah, at first it was only audible when the engine was cold, but eventually it got to a point when it was pretty pervasive.
Post by: Horatio on February 28, 2012, 07:24:56 pm
SNAP!
 :sad1: Ive sent you an email with vid attached, if you dont mind  :ashamed:
Post by: Saintsteve on February 28, 2012, 07:37:41 pm
No email as yet?? just looked...
Post by: Horatio on February 28, 2012, 07:51:23 pm
quick off the mark!  :driver: just sent
Post by: Horatio on February 28, 2012, 08:35:41 pm
Video outside, excluding the squeakyness. The rusty bolt at the centre of the video, above the belt, is making all the noise, it seems to me. WHat is it?  :confused:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi166.photobucket.com%2Falbums%2Fu94%2Fhansumbwunderful%2Fth_Video00211.jpg&hash=db9afb90805f8cf4609d0505ea2550af7212c763) (http://s166.photobucket.com/albums/u94/hansumbwunderful/?action=view&current=Video00211.mp4)
