All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: riz on April 29, 2009, 01:05:56 pm
aaaaaaaaaargh
Went to undo the screw on my number plate and the front screw star heads have dissapeared!! There is nothing there!! What can i do??
Urgent help, DVLA plate change was yesterday!!
drill the heads off to allow you to remove the plate.
Then you could undo the stumps whats left with a pair of pliers.
Would need new fixings from halfrods too
Alternatively chuckem and order a new set www.fancyplates.com (legal or otherwise) and stick the new ones one , much neater :happy2:
hth
John
If you have got a dremel, you can cut a notch in the head and use a flat head screwdriver to remove the screw.
I've had it happen to me many a time, mole grips are normally what save me!
sorted bit of drilling and a set of pliers!!
