All Things Mk5 => How to Guides / Troubleshooting => Topic started by: benjii on February 22, 2012, 05:46:09 pm
Hi everyone well my passenger door won't opening when I press the unlock button on my key once but if I press it a few times it opens and with the boot it won't open with the key boot button or the button inside the car but if I press the unlock button the boot unlocks anyone know why is this a coding problem
You need a scan with VCDS to find out. Door lock intermittent faults are relatively common issues. Find a member near you in the VCDS sticky section & ask them to run a scan.
From what you post, there's no way to tell.
Take a look at this http://www.mk5golfgti.co.uk/forum/index.php/topic,31476.msg390947.html#msg390947
Mine does the same. Your car is set up to unlock the driver's door only on the first click of the remote. If you've got a highline display, you can change this yourself in the settings. It's designed to make it harder for someone on their own to be hijacked when they returns to their car.
The boot unlock on the remote only works if the rest of the doors are locked. Once you've opened and closed the boot again, it automatically locks itself.
Thanks src puts my mind at rest :happy2:
