		All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: smokey on February 22, 2012, 06:17:28 pm
				Hiya Guys
 I was wondering if you could tell me if all mk5 Golfs have the VW factory amp installed? Is there a way to check?
 Following some guides on installing RNS-510's it says when coding to set to the correct amp so that the sound quality is improved.
 I found when i set to the VW factory amp the sound was reduced and i would need to have the volume quite high. Even on max its wasn't that loud.
 Tonight in VCDS i set it to "no amp installed" and now the volume is allot higher. I've noticed GALA is more noticeable too.
 I have 6 speakers in the front and 4 in the back, if that helps?
				Look under the seats. IIRC the factory amp was fitted under the passenger seat.
				Yeah I had a look there but all I could see is pipes for the hvac, so I don't think I have an amp. Would it be listed on the sticker in my car manual, which shows the codes for the added extras?
 That's correct  :happy2:
 Mine is under a plastic cover at the front of the underside of the seat, 10 speaker setup on a later than 2006 car and rcd500  were included with the amp as part of the 'sound pack' option
				Could someone post a picture so that i can check mine please?
				My Ed30 has 10 speakers, but cannot see any amp (although tbh im not lying in the footwell upside down trying to find it, the RNS510 is loud enough for me anyway  :happy2:
 Hi Myles
 You don't have one in your car
 Of all the cars I have looked at I have only seen it on one
 Ed
				Thanks for the replies guys
 So for coding the RNS-510 the following should be done if you dont have a factory installed amp:
 Byte01 - 00 no sound system
 Byte02 - 04 4 speakers
 Byte04 - 04 front and rear
 Byte05 - 00 leave as is
