All Things Mk5 => Mk5 General Area => Topic started by: Frenzy on February 25, 2012, 07:01:36 pm
I think i've been a right old doofus...
I checked the oil this morning, on level ground, cold engine. Dipstick showed oil level at about a 1/3 over min. Last time i checked a few months ago it was 1/2 so i thought i had better top it up. I topped it up with 250 ml then drove it 80 miles (no thrashing, very rarely hit 3k rpm in 3rd gear or above and never went near 4k). I let the engine cool and now the dipstick is reading that the whole of max is covered :scared:.
Am i within a tolerance that won't lead to frothing or Cat damage or have i been a proper dipstick and do i need to get some drained? (i'm guessing this could be likely as Max should mean Max).
Just to repeat - oil level was a 3rd on the dipstick and i put in 250ml - I guess i only needed to put in 100ml or less but should have done so in very small increments and kept checking the dipstick... :sad1:
This is why VW recommend you don't fill more than halfway mark!
do you reckon getting the excess drained is in order then?
tia
tia
just repesting what was already said :grin:
"This is why VW recommend you don't fill more than halfway mark!"
It's nothing to worry about.
If it needs to I believe it can burn any excess anyway
Wouldn't get too excited about it. The TFSI engine is quite adept at reducing its own oil levels. :rolleye:
That much oil won't do the slightest bit of harm. :happy2:
Thanks very much for all the replies and the reassurances - turns out i'm an even bigger doofus as i wasn't taking a correct reading of the dipstick - you see i never had a rag to clean it, replace and then check - i simply took it out saw it all over the dipstick and thought "Oh Fubar what have i done" I also did it whilst the engine was slightly warm (only let it cool didn't check when cold) and wasn't exactly level now i come to think of it :rolleye:
I properly checked it this morning and it is just a little above half way :happy2: Panic over - and before anyone asks, no there isn't an oil slick beneath the car or in the engine bay :signLOL:
