All Things Mk5 => Mk5 General Area => Topic started by: nathangallo on February 26, 2012, 02:56:27 pm
Is it hard to remove the red trim and grill from the gloss black part of the grill
No just presses out from behind. Just be careful as they are quite easy to break
Are you painting the red trim?
No I'm going to buy a new grill which has a damaged honeycomb top and a bit of the red trim missing as I want to take the front reg plate off,
I want to paint to red trim another colour just havnt got a clue what colour to do
ive seen a neonish blue stripe on the same colour as yours, silver gery?. Thats was many years ago. Complemented the colour very well :happy2:
I may just wrap it and see what it's like then if I don't like it remove it :signLOL:
if i read this right...are you relocating the number plate? where? i would love to have it front nearside corner, like Alfa's but sure i have heard its not legal or something.
Well I was just going to put it in window but I have seen people mount it with a square plate on the side and it does look good!
you got any links for that? i just googled and came up with nothing when looking for different mounting locations.
Nah I havnt fella I've just seen it randomly on here but I expect there is something out there! If you see anything give us a shout! :driver:
The red strip is removable, but the honeycomb part isn't.
You can take off the whole honeycomb grille and number plate area though if that helps.
Also, don't put your numberplate in the windscreen, it's illegal, and when you do get pulled you will more than likely start a thread complaining about being pulled. :happy2:
