All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: vRS_Pagey on February 27, 2012, 10:43:03 am
Title: Does anyone recognise these?
Post by: vRS_Pagey on February 27, 2012, 10:43:03 am
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fautoparts.supplierlist.com%2Fpicl%2Fuppic_s%2F201008131556161589.jpg&hash=be97bbbd4ffc94f5018a78db5edd94cbed2082df)
 :popcornsoda:
Title: Re: Does anyone recognise these?
Post by: monte on February 27, 2012, 11:18:18 am
Unprinted R32 calipers???
Post by: JackG on February 27, 2012, 02:16:50 pm
I'm with this guy  :popcornsoda:
Post by: james on February 27, 2012, 02:51:40 pm
100% r32
(I changed my mind, not r32)
Post by: liver on February 27, 2012, 02:55:28 pm
i bet they are not exactly r32 brakes, look identical to them but alot of cars use these brakes with different sized discs aswell
my bet is its something along those lines, it would be too simple to just be r32 brakes
Post by: james on February 27, 2012, 03:01:21 pm
i think your right,  looking at my r32 brakes, both nuts are set in.  You can see the bottom ones are not.   i think the piston is bigger also.(r32)
Post by: JPC on February 27, 2012, 03:19:30 pm
ATE make the r32 brake calipers for the vag group. ATE also supply a lot of other manufacturers with they're brakes. So you will see that caliper design all over the place with an infinitely varying spec sheet when it comes to mounting points and pistons
Post by: MAT ED30 on February 27, 2012, 04:14:15 pm
Post by: vRS_Pagey on February 27, 2012, 04:28:47 pm
They are for a Volvo XC90 running 336mm discs......... :happy2:
I just thought it was an interesting discovery which could open up the possiblities for members who are on the hunt for an R32/S3  Cupra set up.  :wink:
