All Things Mk5 => Mk5 General Area => Topic started by: Weston on February 27, 2012, 07:56:46 pm
What resistor should I use to trick the canbus system into thinking my fog lights are still there once I've fitted DRL's?
I know I can disable them with VCDS if I can get access.
I have recently fitted LED fog bulbs and I had bulb out error on dash, then I chucked these inline and voila, a happy canbus :wink:
http://www.mobilecentre.co.uk/12-volt-ballast-load-resistor-indicator-kit-with-cable-p-93.html
Thanks :happy2:
