		All Things Mk5 => How to Guides / Troubleshooting => Topic started by: blackbess on March 01, 2012, 06:22:42 am
				Hi,
im driving a RHD Golf GTI MY08 and i've been looking high and low the canbus module. Other website refer for the LHD location module. Pls help......
				it will either be behind the glovebox, above the clutch pedal or behind the gearstick
good luck
good luck
Not sure about behind the glovebox. I think the most likely place on an 08 is behind the storage box to the right hand side of the driver (the one below the light switch). If you remove the panel above the pedal box and look up and to the right of the accelerator pedal I think it will be there. Apparently this is the easiest of the three potential locations to get at!! Look for the tell tale red plug which connects up the gateway, much easier to spot than a black box in a field of other black boxes.
				The Gateway can be 3 possible locations
1. Behind the ashtray (MY2004)
2. Above The clutch Pedal (MY2005 & MY2006)
3. Behind the Relay carrier plate (MY2007 - Current)
behind the Ashtray
Pull on Gearknob Gaitor, You will see 2 T20 Torxs screws, remove these and lift
Unplug the ESP and 12v
Look for a RED PLUG at the back
Unplug it and remove, nip the lugs on the back and pull towards you
Undo the 2x Torx screws of the drivers footwell trim and lower it down.
The Cubby bin under the light switch, nip the sides in and pull it towards the drivers seat. You will see a Torx screw that holds the lower duct pipes in place, remove the screw and pull the ducting out.
The gateway will be up and look for the RED Plug
Unplug it
Prise the Plastic holder away from the metal frame with a slotted screwdriver
and remove it with the gateway in place.
Change the gateway over and reset the plastic rivet which held the holder in place.
And refit it
Remove the Cubby bin under the light switch
Unclip the relay carrier and move to one side
Look at the back for the RED PLUG
Unplug it and lift the gateway out
refit new gateway
http://www.r32oc.com/tutorials-guides/30166-canbus-gateway-location-removal.html
http://www.my-gti.com/2296/can-bus-gateway-removing-installing-and-upgrading-volkswagen-golf
I changed a Gateway in a Passat 3C and the plug was Blue in colour, have also heard of blue plug in a Skoda Octavia
