		All Things Mk5 => Mk5 General Area => Topic started by: ConeKiller on March 03, 2012, 12:07:31 pm
				Hi everyone
 When i accelerate i get a whistling sound from the engine, can hear it right from low revs up to high and it gets louder, with the windows down its really obvious.
 I know at high boost when you let of the accelerator it makes a whoosh as normal but im not sure on the whistling, im sure it wasn't like that when i bought it.
 Any advice? from what ive read so far im guessing its the diverter valve?
 cheers in advance
				Sounds like the dv has a split in it as I had the same on mine. If you've got an ED30 only takes 5 mins to check, if standard GTI takes a bit longer due to being in a different position
				I get a whistling sound from mine too - I put it down to the turbo spooling up. As Nathan said - get the DV checked / replaced though first :happy2:
