All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: ianv5 on March 08, 2012, 12:36:23 pm
As above is it a job I could do myself or does it need to be done at a garage?
As long as you have the correct tools and a vice then you should be able to do it.
You really need an impact gun, multi spline sockets, cv clip tool and a big copper hammer.
no,no,no..the shaft doesnt need removing from the car,easyly done with the right tools(if your a technician)
So what tools will I need?
I had the front wheel off yesterday and from my understanding I need to remove brake caliper and front disc to get at the outer CV boot?
Anything else?
Despite contrary advice above when I did one I removed the driveshaft. Not much extra work and much easier to do on the bench etc.
Getting the CV joint off was quite hard but a Master Tech gave me the advice of using a driveshaft bolt driven right down the centre, preferably with a windy gun (which I guess makes it easier if you leave the shaft on the car) to push the CV joint off.
Oh yeah.. Good luck :signLOL:
