		All Things Mk5 => How to Guides / Troubleshooting => Topic started by: jaz on March 13, 2012, 09:43:49 pm
				Hi Guys,
 The CAR: I've got a mk5 GTI 55plate DSG 66k miles.
 Problem is excessive noise - It's recently become more noticeably more louder from what sounds like an exhaust sound which increases upto 70mph then goes away  the sound is so loud.. that  only a stereo can drown it out  when the speeds are in the 60mphs.
 I'm a bit baffled as an inspection of the exhaust under throttle has revealed no holes.  could it be a bearing?
 Any pointers would be much appreciated.
 Cheers, Jaz
				Does the sound increase with the engine or gearbox speed? Also consider a constant velocity joint.
				Fixed... it was worn bearing. :laugh
 Took it into an powerflow garage toda, they had a look seeing there was no exhaust probelm, we' proceeded to a  test drive and all agreed there was rasp like, with a lot of speculation for bearing failure in DSG box... with lots of head-scratching and  back on the ramp's I'd intervened spinning each wheel, to find  one o/s/r wheel gave a slight rasping sound (but no lateral bearing play) . swapout £97.20 (OEM bearing ) + £50.00 installtion fixed it. :happy2:
