		All Things Mk5 => Mk5 General Area => Topic started by: nezquick on March 21, 2012, 08:44:28 am
				Hi, I need new brake pads for the mk5 gti standard brakes as mine have little life in them.
 I would like a pad that is better than oem and don't mind paying a little more as I will be fitting them myself for the first time under my friends dad's exmechanic-exracingdriver-super-hawk-eyes so will be a interesting experience, I'll probably end up making the brew but at least I'll learn.
 A website link to where I can make the purchase would be lovely too  :happy2:
 :drinking:
 Thanks!
				 www.tps.co.uk
 trade parts  I think they only do  VAG spares      otherwise brakes international in Preston
				TPS got an offer on for brakes at the mo too - just got my front pads for £39  :happy2:
				Is there a particular set? i want something better than oem - links please!
 that tps link takes me here http://www.advantageresourcing.com/technical/default.aspx?opcoid=2044  :confused:
 is it http://www.thetradepartsspecialists.co.uk/ that im meant to go to?
				The EBC green stuff are a good next step up upgrade from OEM and benefit in less brake dust
 http://www.psituning.com/product.php/20072/ebc_green_stuff_front_brake_pads___golf_mk5_2_0_petrol_diesel
				I've heard a lot of negative reports about EBC brakes.... Do you fit a lot of them PSI?
				Plus do we get forum discount  :P and much hard on the mk5? its the first time ill be doing it on this car
				Our most popular ones here that customer request and we fit are the Ferodo DS2500's but have no wear indicator and arent currently 'insurance approved'
 "and much hard on the mk5" ? to fit?
 Sorry all our prices are discounted as much as we can offer
 Sorry, are they hard to fit on the mk5 gti? that was me being stupid! Which out of the two would you recommend? and how much is it for front and rear? I can only see front pads.
 Thanks, always worth a try  :smiley:
				Brembo have recently released HP sport pads which are all the rage and comparable to a DS performance pad (the ferodos are £116.23 inc vat for fronts compared to £106.92 for the new Brembos
 Nothing specially awkward fitting them on the Mk5
 Trade only I thought? :surprised:
				PSI how much could you do front and rear HP sport pads for? failing that how much for a EBC red front and rear?
				I would also be interested in prices for the new brembo hp please.
 Front pads for R32 mk5 setup
 Rear pads for GTI 286mm setup
 Also, can you get hold of mintex 1144 pads, and if so prices for the above.
 Thanks.
				Front & rear on the Mk5 GTI
 £204 all in
				and 209.40 all in for the HP on R32 Mk5
				What would that be for r32 fronts and GTI rears?
				Are the Brembo pads mentioned E90 stamped?
 Thanks.
 R32 and GTI have the same rear brake pads don't they? Different calipers, different diameter disc but same pad?
				I think you might just be correct  :happy2:
				Yes rears are the same
 And yes E90 stamped
 Depends on the branch - they are 'supposed' to be and some will turn you away, but the Exeter branch has always been fine. :happy2:
