All Things Mk5 => Mk5 General Area => Topic started by: Sammy on March 26, 2012, 01:47:28 pm
Title: Audi S3 intercooler upgrade
Post by: Sammy on March 26, 2012, 01:47:28 pm
What is needed to install the s3 cooler on a gti? Also is there any modifications required?
Title: Re: Audi S3 intercooler upgrade
Post by: vRS Carl on March 26, 2012, 03:18:17 pm
Just the intercooler and the two pipes.
Depending on your model year you may need to alter the pipe on the side to fit
Post by: Sammy on March 26, 2012, 03:20:16 pm
Depending on your model year you may need to alter one of the pipes to fit
What two pipes are needed? Also I have 2005 would that need altering? Do u mean modifying one of the pipes to fit?
Post by: vRS Carl on March 26, 2012, 03:29:38 pm
This is what you need
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww.jkm.org.uk%2Fperformance%2FMisc%2FMisc_Performance_pictures%2FTFSI-images%2FOverviewpage%2FIntecooler%2Fs3corejkm_big.jpg&hash=94a296c754574da1f8b350fc24ab3708c0ff6bdc)
The connector on the end of the Turbo discharge pipe is slightly different depending on the year. If you get the year where it's not a straight fit (RH Pipe in the pic) then you can cut the end off and use a connector from forge to get it to fit.
If i can find the pic of the differences i'll post it up :happy2:
Post by: Sammy on March 26, 2012, 03:44:54 pm
Thanks Carl, have you got a part number for the S3 intercooler? I know theres 2 different types 1 being the plastic ended?
Post by: vRS Carl on March 26, 2012, 03:48:58 pm
S3 Intercooler - 1K0 145 803P
Left Pressure Hose - 1K0 145 834 AA
Right Connection Hose - 1K0 145 832 L
Not sure wether that is for the old one or the new one with plastic end tanks. I would have to check with ETKA which i won't be able to do till later this evening.
Post by: Sammy on March 26, 2012, 03:59:14 pm
That's brilliant  :happy2:
I have a intercooler with part number: Intercooler - 1K0 145 803 BP
I think it is from a mk6 gti but iv been told it is the same as the S3 one, how true is that?
Post by: Sammy on April 11, 2012, 05:04:41 pm
Right so I have my s3 intercooler now and it came with 1 hose part numbered   1k0 145 832 ad, does anyone know the part number for the other hose that I need through ETKA?
Post by: RedRobin on April 11, 2012, 05:19:06 pm
....Interesting if true but a surprise  :surprised:
Post by: Sammy on April 11, 2012, 05:42:59 pm
It must be where the Mk6 GTI gets the extra 10 bhp than the MK5 GTI lol
Post by: Tinytim on April 11, 2012, 07:46:53 pm
Really interested in this mod. Does anyone know how much this is roughly from TPS?
Forgive my ignorance but where about exactly is the intercooler mounted?
Post by: RedRobin on April 11, 2012, 07:52:24 pm
....Behind the 'water' radiator.
[Where's the water radiator mounted? I hear you say]
The whole front of the car has to be removed to install it - Hence the labour costs.
Post by: ktlstar on April 11, 2012, 07:53:37 pm
IIRC it sits between the radiator and the aircon radiator.
Post by: ktlstar on April 11, 2012, 07:55:38 pm
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi40.tinypic.com%2F344zl09.jpg&hash=83e49bfbfc0174ffb5ef723a135fb03ac939e962)
Easy once you get it looking like this lol.
Theres a guide on the site somewhere to help you on your way.
Post by: RedRobin on April 11, 2012, 08:00:16 pm
There's a famous thread of a member here (illyun) who took over 11 hours to fit his intercooler and then had quite serious problems resulting afterwards. IIRC, JKM helped him out in the end.
Post by: Tinytim on April 11, 2012, 08:28:41 pm
I presume the S3 intercooler is bigger than the ED30 one and improves cooling.
Any other benefits?
Post by: Sammy on April 26, 2012, 09:01:18 pm
Thsi thread people are saying only two pipes, But i just read somewhere you also need some sort of M16 bolts?  :confused:
Post by: vRSAlex on April 26, 2012, 09:59:20 pm
I believe that's only with the metal end tanked cooler.
I removed a mk6 cooler to fit a ths cooler and I don't remember it being any different to the standard mk5 cooler.  Would be nice to see the coolers all next to each other for comparison.
Post by: the bruce on April 26, 2012, 10:37:17 pm
Mk. VI GTI + R is thicker than Mk.V GTI. Same thickness as the old S3 IC.
Just plastic end tanks but improved core.
Post by: Vick N on April 27, 2012, 10:35:43 am
Just to confirm guys, the above parts will go straight onto a mk5 ko3 Gti?
Many thanks
Vick :)
Post by: Sammy on April 27, 2012, 11:53:05 am
Same thickness as old S3 intercooler or do you mean same as the latest S3 8P?
Post by: the bruce on April 27, 2012, 12:09:45 pm
Both.
Mk.VI GTI = Mk.VI R = Scirocco R = current S3 2010 on = TT-S and some more
All these have the same IC currently. This IC has the same dimensions as the former full metal S3 IC.
