All Things Mk5 => Mk5 General Area => Topic started by: Sammy on March 28, 2012, 10:33:11 pm
What is this part and what does it do? Is it worth fitting and what are the actual benefits?
Not being funny but use the search button there is alot of info on this in great depth :happy2:
I already did, didn't find anything to do with benefits?
http://www.mk5golfgti.co.uk/forum/index.php/topic,43589.0.html
I searched it and was second thread.
Only helps for people who are stage2+ which the map requests 130bar of fuel, limiting the OEM valve at 130bar. The RS4 is 136bar IIRC giving it some room to play with.
PROS: Flat spots up in the higher rev range clears up when this is fitted.
CONS: A pain in the ass to fit, 30 minutes if you know what your doing!
