All Things Mk5 => Mk5 General Area => Topic started by: s3dubbin on April 13, 2012, 01:49:58 pm
I went and screwed up and spiked the battery on my s3 8p with the wrong terminals now my car wont start? Any ideas would be massively appreciated. Turns over tadadadadatdadada but will not fire? Checked all fuses in engine box and on drivers side cabin but all seem ok? I fitted my new intake and catch can the other day but think it is more likely to be the battery spike? Battery seems good, new plugs and coils. Fault code is terminal 30 low voltage. Cheers, Stevie. :sad1:
you tried clearing the code first
Cleared the code last night Mat. Forgot to say the car has been up and running four times......now nothing.
you getting fuel and a spark then?
Loads of fuel, had the pipe off and fuel was pumping, engine bay stinks of it. Plugs out dried and cleaned but no spark.
going to say sounds flooded
Can you vcds software still connect to the ecu?
You tried a push start? where you get someone to push or tow you, keep it in second and then lift the clutch up with some gas and turning the key, might work might not?
I did this once in a skoda fabia and worked a treat after driving around for a bit it seemed to sort out what ever problem it had.
oh and have a look at this
watch from around 1.50 in where it talks about the sparks then use a phone to record the spark plug to see if your sparking
&feature=relmfu
Thanks nezquick I cannot have a look at the vids from work but will have a look when home. A bump start was mentioned last night. Might try that tonight. Just seems a little more serious than that. They keep going on about checking the earths, where are they?
thats alright mate, yeah have a check tonight - the guy is a little enthusiastic but he makes some good pointers.
When you do bump start make sure its in second not first - if it doesnt start from that then you've probably got a spark problem which is where the second video helps as he shows you how to test if your car is sparking (so use a new spark plug or one you know works) if you get no spark then you have something wrong with the control of the spark i.e. your car isn't sparking because of a problem either mechanical or electrical.
The only other thing I can think of which might of happened (i hope not) that happened to me once was the timing went off and the car refused to start which ended up costing a small f***ing fortune, before It stopped it went into limp mode and cut the speed to thirty but just after I got of the motorway in bristol and lasted enough to get me to the garage, a lot of popping and banging and a really loud idle - loads of people just stared and thought "what the f has he got under that bonnet" (i loved the sound like a old muscle car with that supercharged idle with the rough fast to slow fast to slow lol) and he said it started once afterwards backfired a load and then stopped and wouldnt start. a week later he phoned me and said the chain had jumped some teeth on the timing probably due to the rough idle.
hope it isnt the later and you get it all sorted!
Did they mean the battery teminal? you need to make sure the poss and neg are attached tightly enough to keep contact. The earth points im not sure but i thought they were normally on the block of modern engines? someone will point you into the write direction on that one.
double check your fuses as well
Seems I hav fried my ecu. Lesson learned! :confused:
Sh*t :scared: :sad1:
This is why I originally asked if you could communicate with the ecu.
pm sent maybe be able to help
There's an S3 just gone in car parts for breaking if it helps. Fingers crossed for you mate, always silly mistakes that cost
Got auto spark arriving at 2pm to diagnose prob. How does he narrow it down to being 100% ecu problem? Is there a test? Thanks lads, Stevie.
Are you sure you've fried the ecu, that noise is the same as low battery voltage failed start. If you have rapidly discharged the battery then it could be fubar and it needs 12v for the various computers to operate so an 11v battery wont turn the car over and jump start wont help.
Have you put a new battery on? If VCDs or similar cannot communicate with car with a fully charged (known good) battery you may well be right about the ecu :sad1:
No i am not sure. I have not rapidly discharged the battery recently. I have tried two batteries in the car. I phoned my audi garage told them the story, straight away they said ecu. Stevie.
If it helps, we can clone the ME9 ecu, this means you can buy a second hand ME9 from another TFSi and we can copy all of your cars memory dumps onto it.
Will gladly do it at postage costs plus a few beer tokens :happy2:
By connecting the wrong terminals you would have put the positive terminal to the earth and the battery would have discharged, you might well have an issue with the ecu but if you get the clicking sound and the cluster dash picture red screen starts going dark and funny then you have an under voltage battery. I've had this on several occasions due to a battery drain issue so worth getting a volt meter on it to check the voltage.
Still not 100% sure it's the ecu yet. Had the coils out of the car yesterday with the plugs plugged in, cranked it over to watch the spark and the plug sparked everywhere apart for the place it's meant to?? So when I thought it wasn't sparking it is actually. New plugs arrive tomorrow then after that I am kind of stuck. Thank you very much pdt that is very very kind of you it might still come to that, see what price west comes back with on the s3 ecu. Not giving up. Appreciate all the help. :happy2: Stevie.
Remember to hold the body of the plug (threaded section) against an earth while testing the spark)
