All Things Mk5 => Mk5 General Area => Topic started by: brin on April 23, 2012, 07:19:19 pm
Title: Awful metal on metal sound whilst driving
Post by: brin on April 23, 2012, 07:19:19 pm
Hi Folks
Newbie here but been reading the forums since getting my 56 plate GTI in October last year which I must say has been phenomenal up to now!
I drove to work as normal this morning and all was fine, as I was pulling away from work this evening I heard the most evil sound which appeared to be coming from the offside rear. I have noticed that if the car has been sat for a day I sometimes hear a clunk as I take the handbrake off and pull away so possibility related. The thing is the noise happens constantly, the breaks work fine and the noise doesn't change when applying them. I decided to turn back and leave the car at work and as I drove back the noise got worse.
I'm wondering if the pads have gone and are welded to the discs? I did check for any score marks on the back disk but nothing was visible and if I remember rightly the car will let me know once the pads need replacing anyway. Has anyone else experienced anything similar?
Thanks in advance
Brin
Title: Re: Awful metal on metal sound whilst driving
Post by: MAT ED30 on April 23, 2012, 07:20:43 pm
you might have stone stuck in the brakes i.e. behind the splash guards i have had this loads sounds horrid
Post by: QD MBE on April 23, 2012, 07:21:52 pm
stone caught between the splash guard and the brake disc.
Post by: QD MBE on April 23, 2012, 07:23:38 pm
just push the splash guard gently away from the brake disc, and it should fall out.
Post by: TagnuT on April 23, 2012, 07:27:42 pm
+1
Had that myself, sounds horrid.
Post by: brin on April 23, 2012, 07:27:59 pm
Thanks for the responses, the cars at work so will give that a go before I call the AA in the morning - you may have saved me some embarrassment!
Is the splash guard the bit which sits nearest to the centre?  :ashamed:
Thanks again
Brin
Post by: RedRobin on April 23, 2012, 07:36:54 pm
....x 2.
It really is a horrible sound and you can't help think the worst until you know what it is.
Post by: higher1 on April 23, 2012, 07:40:10 pm
Try reversing as well sometimes this works
Post by: MPS on April 23, 2012, 07:53:42 pm
I've had the old stone stuck between the disc and splashguard thing twice now!. Just a gentle push and you might hear the stone as it hits the ground!
Post by: gulfstream11 on April 23, 2012, 08:04:13 pm
As said.. definate stone.. I had it,got scared,called the RAC.. He listened to my explanation of the noise,tapped the splash guard.. Sorted.. I was really embarressed.
Post by: blackmagic on April 24, 2012, 01:42:12 am
I had the stone thing last week as it happens. It's first time for me and did give us a scare. Thought the whole wheel bearing had collapsed! Got out gave a push on splash guard and out dropped the stone.
Post by: Tfsi_Mike on April 24, 2012, 07:28:38 am
It sounds like your exhaust is dragging on the floor. horrid noise.  had it a few times and as above was stones between the disc and splash Guard
Post by: RedRobin on April 24, 2012, 09:18:19 am
....Exactly what I first thought was going on!
A very good way to describe the noise, Mike  :happy2:
Post by: brin on April 24, 2012, 09:47:06 am
Yep sure enough, got to work, pushed the guard back and the stone dropped out!
Thanks again
Post by: Mk5 GTian on April 24, 2012, 09:09:21 pm
I had this tonight as I was leaving work. Me and my mate were on our knees looking to see which bit of the exhaust had come off!
I reversed very slowly on his suggestion and the stone must of just fallen out.
If this happens again, what bit is the splashgaurd? Does anyone have a pic of one please?  :happy2:
Post by: brin on April 24, 2012, 09:39:39 pm
It sits behind the disc, but is slightly larger. So you can push the edges with your finger and it flexes enough for it to drop out
Post by: RedRobin on April 24, 2012, 10:28:51 pm
....Splash guards, also known as stone guards, are not something which folks feel a strong desire to photograph for some reason  :grin:
It's the thin metal shaped disc which is mounted parallel to and near the inside face of the disc brake. They are usually painted black.
I don't have any fitted on my rear S3 brakes.
Post by: skard on April 25, 2012, 09:31:40 am
As mentioned, it's the large metal plate behind the discs.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi278.photobucket.com%2Falbums%2Fkk99%2Fonlinephoties%2Fdustshield.jpg&hash=1780670b9279ab3490b984547ba51a17c5835bfb)
Post by: RedRobin on April 25, 2012, 09:50:15 am
Just how important are these metal disc stone guards? Especially when they trap stones and probably do more potential damage than a quick strike.
Post by: Mk5 GTian on April 25, 2012, 05:26:53 pm
I take your point Robin. "Pwhoar, nice stone gaurds!"  :grin:
