All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: four! on April 26, 2012, 10:51:54 pm
Title: Changing from midline to highline (Advice required)
Post by: four! on April 26, 2012, 10:51:54 pm
Hi,
Managed to collect a few highline parts for my gt 140 so was looking into the procedure for fitting them.
I have collected so far, MFSW,  Highline clocks (973B) and Highline steering controller. All from 07 my car same as mine.
Am I correct in thinking I need a small airbag loom and does anyone have a part number to hand?
I do have access to VCDS so can code the controller and wheel but im confused as what to do with the cluster.
From what I have read I need the 7 digit SKC from my current cluster, Can I get this from using VCDS? If not how?
I assume I also need the same from the new (used) cluster. I understand this one is not possible to get using VCDS, what's the best way to do this?
I would then need to match the mileage, what do I need to do this?
I did have a read through a thread on here which went into it but I believe it is for the older clocks 971 type
Many thanks :smiley:
Title: Re: Changing from midline to highline (Advice required)
Post by: Phil Miller on April 26, 2012, 10:59:22 pm
Hi mate to code the SKC to your new cluster you will need to talk to Kalu on here, he can do the 973 and 974 clusters aswell as the mileage correction, the airbag loom you need is part number 1K0 971 584C and will cost you about £25 from TPS
Post by: jameelno1 on April 26, 2012, 11:02:43 pm
you need vag commander kit to do the clocks i believe its only 74 model clocks that can only be done from dealer
skc can only be obtained from vag comander as is changing the mileage
Post by: Phil Miller on April 26, 2012, 11:08:05 pm
Vag commander wont do 973s ive tried and its not having it, dealers will only program BRAND NEW clusters they wont do old ones, you will need to PM kalu
Ive retrofitted loads of the older 972 and older but cant do 973 or 974, cant even correct the mileage on them
Post by: james on April 26, 2012, 11:32:23 pm
i have done 973s with my Vag commander, just no luck with 974
Post by: Phil Miller on April 26, 2012, 11:46:25 pm
Are you using 5.1?
Post by: vw55raz on April 27, 2012, 12:15:42 am
I'm doing mine this weekend. Got a set of 971 clusters as I originally bought a 974 too. But pm Kalu on the forum. He can advise you on what's best with 974 clusters. I think they have to be taken apart to retrieve skc number
Post by: Eddie-NL on April 27, 2012, 05:35:28 am
You were probably lucky to do your 973
as most 973 won't work with the clone VAG-commander as they are past the mid 2006 change
Post by: four! on April 27, 2012, 07:01:40 am
Thanks for the help so far guys. Cheers for the part no Phil  :happy2:
I managed to get an exact match for the clocks, were 963B and found 973B's
Does VAG commander not normally work on 973's?
Post by: Phil Miller on April 27, 2012, 10:40:40 pm
Anytime mate  :happy2:
Vag commander doesnt normally work on 973 or 974s, ive never been able to on 973s  and cant do 974s
Post by: four! on May 02, 2012, 08:51:14 pm
Been looking into this a bit more, If I can get the pin and skc from both clusters can I do the swap with vag com?
