		General => Detailing => Topic started by: nathangallo on April 28, 2012, 03:07:39 pm
				really need them looked at there staring to crack and look sorry for them selves
anyone sprayed/painted theres whilst still on the car ??
				Sorry I can't help at this point but I also need to attend to mine on the rear.
I'd like to know what shade they are OEM though as I was advised RAL3020 but it's nearly orange in comparison.
So what colour are the calipers?
				Hope this helps:
Tools and Materials needed
paint - either high temperature caliper spray paint such as VHT  or epoxy brush-on paint
jack and jack stands
brake cleaner (cleaning solvent) in a pressurized spray can
wire brush (brass, preferably); a rotary tool with a wire brush attachment may also come in handy for tight spots
masking tape and newspaper
small paint brush - 1/2" to 1" wide (13 - 25mm)
Choosing the color
The color is up to you.  Strictly a matter of personal preference.  The most common colors are probably red, yellow, black, and blue.  Here's my opinion of each color:
red - looks good on pretty much any color car; my car is red so it was an easy choice.
yellow - also a good universal color, but some would say it's played out...a little too flashy.  But if you like it, go for it.
black - the understated color, won't get a lot of attention but won't show brake dust as much, either.  Looks at home with any color car.
blue - I think it works well with blue, yellow, or black cars, but please don't do it on a red car.
Getting the car off the ground
Before jacking up the car, use the lug wrench to break the lug nuts loose 1/2 turn.  Set the parking brake and jack up one side of the car so that both wheels come off the ground.  Find sturdy spots on the frame for the jack stands.  Put one toward the front of the car and another toward the rear, then slowly lower the jack until most of the weight is borne by the jack stands.  It's a good idea to shock the wheels on the opposite side of the car with something like bricks or cross-ties to be extra sure the car can't roll off the jack or jack stands.  Now finish removing the lug nuts, pull off the wheels and set them aside.
Surface preparation
Start by scrubbing the calipers with the wire brush dipped in gasoline, mineral spirits, or some other solvent.  If you notice any stubborn spots, especially in tight spots where the brush won't reach, use some sandpaper wrapped around your finger to scrub it clean.  Then follow up with some spray brake parts cleaner.  It's a fast-drying solvent under high pressure that blasts away any latent debris and leaves the surface ready to paint.
I can't overemphasize the importance of surface preparation.  I'm convinced that's why mine have held up so well.  If there's the slightest bit of oil or debris left behind, the paint will be much more prone to chipping and peeling.  You want to start with immaculately clean calipers.
Finally, use masking tape and newspaper (small plastic grocery bags work great too) to mask off the rotors, brake lines, etc...anything you don't want painted.  You can do spot cleanup with acetone or fingernail polish remover.  Any overspray that gets on the friction part of the rotors will burn off the first time you use the brakes.
Painting
I used red Plasti-Kote 900°F caliper spray paint.  I know some people swear by the more expensive epoxy paint, but mine are holding up extremely well.  When they're clean, they look just as beautiful as the day I painted them.
Begin with about four (4) coats using the small paint brush.  As needed, spray some paint into a plastic cup, dip the brush into it and begin painting.  I know it sounds funny to brush on spray paint, but it helps get into the hard-to-reach spots.  Coverage won't be very good at this point, but that's okay.
Now put on about six (6) light coats with the spray can.  The biggest mistake you could make at this point is to go too heavy with it and get a paint run.  Don't get ahead of yourself and try to get full coverage right away.  A run is a big waste of time.  It takes a long time to dry enough to sand it down, or if you jump the gun and try to wipe it up while it's still wet, it makes a mess of the surrounding paint.  Keep applying light coats until you are pleased with the coverage.  Use care and make the last coat a little heavier to smooth out the finish.
The rule of thumb is 15 minutes between coats, but it may take more or less depending on the temperature and humidity.  To check, very carefully touch the surface in an inconspicuous area.  If it is tacky, wait a little longer.  Just don't touch it too hard or in a spot that is readily visible or you might leave a fingerprint.  If you're within the paint manufacturer's recommended temperature and humidity and it's taking much longer than 15 minutes, you're probably applying too much.
If it is below 70°F while you're trying to paint, a helpful trick is to soak the spray can in a bucket of hot water.  Doing so will allow the paint to atomize into smaller particles and give more uniform coverage.
The combination of brush and spray work really well.  The brush gets into the spots that can't be reached with the spray, and putting on the finish coats with the spray gives it a nice smooth finish that looks like it was professionally powder coated.
It may be hard to resist, but it's recommended that you not drive the car for 24 hours in order to allow the paint to properly cure and harden.  You worked hard to do a good job, so don't chance it.  Sit back and admire your work.
				We're did you get your plasti kote from?
Plasti-kote Ltd
PO Box 867
Pampisford
Cambridge
CB22 3XP
or any B&Q Superstore should have it.
				Thanks buddy going to this on th weekend me thinks  :driver:
Keeping them red though  :smiley:
				i just used red smooth hamerite,did them over a year ago
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fcc20%2Fmaxitrol%2FIMAG0168.jpg&hash=3817a0fbb34e2cb4e98f3e5283286555b7280b17)
Painted on?
				yeah just painted on,didn't want to get them powder coated and this way if they get stone chipped i just touch them up
				I thought Davids post sounded slightly American.
http://orca.st.usm.edu/~jmneal/tiburon/calipers.htm
Google FTW eh?
