All Things Mk5 => Mk5 General Area => Topic started by: Sammy on April 30, 2012, 10:20:46 pm
Title: Steering a little too heavy
Post by: Sammy on April 30, 2012, 10:20:46 pm
I came to open this post because I came to realise that my steering feels a bit heavy at car park parking, isn't the gti steering meant to be light at slow speeds and then gt heavier as it picks up speed?
Title: Re: Steering a little too heavy
Post by: Kregiel on April 30, 2012, 10:58:29 pm
i'd like heavier steering on mine, would get rid of the power steering motor if could!
have you checked air in the tires? It could be something simple as power steering is not prone to failure AFAIK
Paul
Post by: monte on April 30, 2012, 11:03:22 pm
I think you can change the steering with Vagcom???  :confused:
Someone will chime in soon.  :wink:
Post by: rich83 on April 30, 2012, 11:08:05 pm
Only pre 2006 if i remember right.
Post by: Phil Miller on April 30, 2012, 11:09:09 pm
Yes you can, there is a page in the ross tech wiki
here you go depends on age of car by the sounds of it
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist
Post by: Sammy on April 30, 2012, 11:09:16 pm
What can I change with vagcom and how?
Post by: Phil Miller on April 30, 2012, 11:10:03 pm
see above mate
Post by: Sammy on April 30, 2012, 11:14:39 pm
Am confused on what needs to be done still?
Post by: monte on April 30, 2012, 11:16:40 pm
Well it sounds like you won't know what to do with vagcom, but if you find someone that does, tell them your steering is a bit heavy and that you would like it setting to a lighter setting.  :happy2:
Post by: monte on April 30, 2012, 11:19:12 pm
From Rosstech…….
"Generation 1 and early Generation 2 still allowed switching between up to 16 different predefined Characteristic Curves, while later/updated Generation 2 and 3 do not and the Adaptation Channel is being inactive/unavailable."
What year is your Gti?
Post by: Sammy on May 01, 2012, 12:31:50 am
Mine is 2005 but how do i know what gen i have?
Post by: monte on May 01, 2012, 12:45:14 am
Gen 1  :happy2:
Post by: john87 on May 01, 2012, 09:50:57 am
My steering felt heavier when I switched from the standard 17's (with winter tyres) to Monza 2's with summer tyres. Definitely affected by tyre pressure though, and road surface... I find the steering is perfectly weighted in my GTI compared to the 'arcade game' light setup in the courtesy Polo I had a few months ago  :happy2:
Post by: vw55raz on May 01, 2012, 10:09:34 am
In vagcom there's an option to select how stiff or light you want the steering to be. But as mentioned above, depends which year your golf is.
Post by: stealthwolf on May 01, 2012, 10:57:55 am
I'd definitely start off  with checking the tyre pressures before fiddling around with settings. Check your fuel filler cap for the right pressures.
Post by: Timvgti on May 01, 2012, 05:36:55 pm
Mine is also from 2005 (Dutch model) and I also want to set the steering a little lighter.
My basic setting in vcds is a value '12', so I am confused and don't know what value to set.
See my topic over here:
http://www.mk5golfgti.co.uk/forum/index.php/topic,43732.msg507530.html#msg507530
Helppp?!?
