All Things Mk5 => Mk5 General Area => Topic started by: Sammy on May 13, 2012, 03:22:10 pm
Title: R32 - S3 brake disc replacement
Post by: Sammy on May 13, 2012, 03:22:10 pm
My discs have to a end now and need changing, What do people think of the following, the options are drilled, or drilled and grooved or just grooved.
Which is the best to go for? Also comes with brembo pads which are crap says the price of the listing? Are the S3 discs meant to be 30mm wide??
http://www.ebay.co.uk/itm/VOLKSWAGEN-GOLF-R32-MK5-3-2-V6-FRONT-BREMBO-BRAKE-PADS-AND-KINETIX-DRILLED-DISCS-/270896811381?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3AAudi%7CCars+Type%3AS3+quattro&hash=item3f12b54d75#ht_2880wt_1015
http://www.ebay.co.uk/itm/FRONT-DRILLED-KINETIX-BRAKE-DISCS-AUDI-S3-2-0-TFSI-QUATTRO-06-/250901931667?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a6aeba693#ht_3198wt_885
http://www.ebay.co.uk/itm/VW-PASSAT-B6-3C2-SALOON-3-2-FSI-FRONT-DRILLED-KINETIX-BRAKE-DISCS-TX060-132-/300679370820?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3AAudi%7CCars+Type%3AS3+quattro&hash=item4601e31844#ht_2017wt_922
Title: Re: R32 - S3 brake disc replacement
Post by: DFish on May 13, 2012, 04:17:39 pm
Depends if you want discs that last. The only drilled discs worth having as those that have them cast in and not drilled after the fact. Cracks galour. :(
Go either plan or grooved if you have to have a pretty pattern.
Fish
Post by: Ree on May 13, 2012, 08:35:53 pm
I have neuspeed disc with yellow stuff pads on my R, see my sig.
These are drilled in way to help negate cracking, I have had them for about 5,000 miles no issues !
Contact Mike at Awesome gti !
Post by: W8 Performance on May 13, 2012, 09:30:03 pm
Speak to DaveB and get discs from him. Job done.
You do get some droning with drilled and grooved discs and as others have said some drilled discs are prone to cracking.
At then end of the day if its cheap then you will be buying more in the near future :happy2:
Post by: Sammy on May 13, 2012, 09:44:01 pm
Does dave b supply normal brake discs or drilled ones? Also how much?
