All Things Mk5 => Mk5 General Area => Topic started by: scarpicus on May 18, 2009, 01:04:27 pm
So I unconnected the yellow connector under the drivers seat (Don't ask why) and than when i re-connected it the air bag warning light came on.
So i turned the car off and than back on and the yellow symbol on instrument panel goes off but than comes back and stays on..
Im sure i just need to clear the fault code that may have come on as a result of disconnecting than reconnecting yellow connector so i wanted to know if i buy this product VVVVVVV would that solve the problem. Thanks
http://www.gendan.co.uk/product_GDVAG.html would that work :happy2:
I dont believe so. As it only says reads air bag codes?
I had my air bag light cleared by a friend with a snap-on scanner if that helps?
Edit: Just read it clears warning lights so am still unsure, would be a usefull piece of kit to have for anyone without access to VAG-COM.
if your still under warenty pop down your dealership they should clear it for nothing mine did.
No im not under warrenty anymore it run out about a year ago
Yeah im unsure wether to trust it or not
maybe il wait till i take my car for service in next two weeks at an independent and maybe they will clear it for free.
Have a look in the vagcom section - see if anyone near you has it and see if they will clear it for you.
Oh and yes by the sound of it the error will just need clearing.
cheers neg :happy2:
Neg did you get my PM?
nope .... try again
