All Things Mk5 => Mk5 General Area => Topic started by: Russ_leeds on May 21, 2012, 11:59:07 pm
Title: knocking when turning right
Post by: Russ_leeds on May 21, 2012, 11:59:07 pm
My car has suddenly developed a knocking noise mainly when turning right and/or a bumpy surface. It sounds quite bad so i've just limped it home :chicken: My mods are in my sig if thats any help  :drinking:
Not what I need really a month before I drive across half of europe :fighting:
Title: Re: knocking when turning right
Post by: markevo6 on May 22, 2012, 08:55:55 am
Sounds exactly the same as mine , it turned out to be a split cv gaitor and the grease had dried out .
I used an independant , the new joint was about £ 50 I think plus the labour to swap it over .
I was initially thinking steering rack , thankfully it wasnt .
Good luck
Mark
Post by: Russ_leeds on May 22, 2012, 09:26:32 am
cheers. I've just been out and started the car and I noticed a rattling noise coming from underneath the front end, also it makes the knocking noise when turning the wheel when stationary?? :confused:
Post by: Tfsi_Mike on May 22, 2012, 09:36:48 am
Hope you don't have to cancel the trip mate
Post by: Russ_leeds on May 22, 2012, 10:08:27 am
cheers mate, me too. Hopefully it won't be too expensive. I'm taking it so a vw indie this afternoon  :sad1: :fighting:
Post by: Russ_leeds on May 22, 2012, 11:02:09 am
Ok so I just took the car for a quick spin round the block and it seems to do it when going over a bumpy road more than when turning, it almost sounds as if its under my feet/centre console.
Any one got any ideas please?
Post by: Tfsi_Mike on May 22, 2012, 11:18:41 am
I've got a quiet knocking too.  Got subframe bolts to see if it helps.
Post by: GrayMK5GTI on May 22, 2012, 11:35:11 am
Sounds a lot like the problem with mine. I tried drop links but they made no difference  :sad1:
Could be your strut top mount?
Post by: Tfsi_Mike on May 22, 2012, 11:45:22 am
New top mounts made bugger all difference  :sad1:
Post by: Russ_leeds on May 22, 2012, 02:04:59 pm
Found the problem, my anti roll bar d-clamp has snapped causing the arb to knock
Post by: reflex11 on May 22, 2012, 03:43:40 pm
i think i had this, when i went full lock i had it, mot failed cv joint replaced it hvn't heard anything since  :drinking:
Post by: Russ_leeds on May 22, 2012, 04:15:46 pm
Cheers, my cv joints are fine, its the clamp from around the driver side of the front arb that has snapped, causing the d-bush to move round so the arb is knocking (metal on metal) on the frame.
I'm just glad its not anything major. I've pm'd w8 performance who supplied them and waiting for his reply.
Has anyone else had this? Mike, Simon seemed to think you'd had this at some point?
Post by: Tfsi_Mike on May 22, 2012, 04:55:32 pm
My front Arb clamp a day after being back on uk roads  :fighting:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi1112.photobucket.com%2Falbums%2Fk482%2Ftfsi_mike%2Fc4cc3427.jpg&hash=f70a60f5b02c13076aefd775c33665badb77587a)
Post by: Russ_leeds on May 22, 2012, 04:59:13 pm
Cheers mate, looks pretty much the same thing, except mine has snapped a bit further up. What arb do you have and what causes this? My arb only got fitted about 4 months ago and I always try and avoid potholes and I pretty much CRAWL over speed bumps
Post by: Tfsi_Mike on May 22, 2012, 05:05:10 pm
Neuspeed 25mm Arbs mate
Poorly lit road, caught a speed bump at 25mph in dover. Knock knock knocked my way to Sy's
Post by: Russ_leeds on May 22, 2012, 10:25:41 pm
I've got the autotech arbs. I wouldn't mind but im certain i've not hit any potholes or speedbumps :fighting: :fighting:
I'm just glad its only something minor really :jumpmove:
Post by: W8 Performance on May 22, 2012, 11:13:08 pm
Russ
Look what I've found :happy2:
Are these the bits you need? They look slightly different to the first lot of bars
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fv675%2Frobert_waite%2F10f8d37a.jpg&hash=a127c595edf4f929eb62b4d66a8428d5d046e817)
Rob
Post by: Russ_leeds on May 22, 2012, 11:16:47 pm
Yeah thats exactly what I need :happy2:
Cheers for your help mate
Post by: W8 Performance on May 22, 2012, 11:22:03 pm
They will be in the post tomorrow and with you Thursday Russ.
Autotech confirmed they will send another set out to me with my order of HPFP's that are leaving now  :jumpmove:
Glad I can get it sorted for you mate, sorry it happened. I broke my front intercooler and damaged the sidewall on my tyre hitting a pothole last year  :surprised: Hopefully the roads in Europe will be better  :driver:
Post by: Tfsi_Mike on May 22, 2012, 11:37:50 pm
There's no doubt the German roads are better, lived there for 5 year and I'd go back tomo  :sad1:
Looks like you've been sorted out there Russ  :happy2:
My neuspeed clamps took 4weeks  :sick: might have been longer
Post by: Russ_leeds on May 22, 2012, 11:43:09 pm
Yeah definitely mike.
Great service there rob. Thanks again
