General => Detailing => Topic started by: berg on May 27, 2012, 11:05:23 am
Title: How many coats of wax needed?
Post by: berg on May 27, 2012, 11:05:23 am
Decided would detail my car yesterday with the products I had in the garage.
snow foamed, born to be mild wash, clayed, duragloss polish, black hole glaze and then for the wax i had some Turtle Wax "Black Hole" carnuba wax.
Now, do I need to put as many coats of the wax on as possible if I want to protect the shine/ get some good beading if it rains??
Title: Re: How many coats of wax needed?
Post by: stealthwolf on May 27, 2012, 11:20:45 am
Two is usually more than enough for any way. Applying more ends up stripping previous layers so you're undoing your work. Then top up as required.
Post by: Alzak on May 28, 2012, 04:58:09 am
Make sure You leave first layer for some time to cure before layering
Post by: berg on May 28, 2012, 10:59:17 am
ok cool, so if want to put a second layer on tonight do i just need to spray dust off with megs detailer first?
Post by: reflex11 on May 28, 2012, 01:03:01 pm
i dont use wax, prefer sealant as it lasts longer, usually you would do 2 coats to make sure you havn't missed anywhere in the first coat :driver:
Post by: stealthwolf on May 28, 2012, 02:09:37 pm
I think most products tend to have a full cure time before which you shouldn't apply a second coat. Some state this on the tub. 24-48 hours seems to work for most but it depends on the individual product. Unless the car has been stored in a dust-free environment where there's no chance of anything settling on the paintwork, I'd rather rewash the car, dry and then appy the second layer. Some people just use a quick detailer for a wipe down prior to application instead.
Post by: berg on May 28, 2012, 02:34:29 pm
thanks
Post by: James B on May 29, 2012, 09:26:18 pm
Two coats is the right wax to do things, not to get two layered coats but to ensure you get at least one good full & even coat down.
