All Things Mk5 => Mk5 General Area => Topic started by: edd666999 on May 30, 2012, 02:13:05 pm
Im stage 2+, what peak boost ish would you expect to see on my boost gauge?
Im sure its dropped sightly.
I wouldn't entirely trust your boost gauge.
With vcds I usually see 2580mbar (inclusive of atmospheric pressure) though this is the limit of the map sensor so actual could be a little higher.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww.newsouthperformance.com%2Fimages%2Findigo%2Fgaugeface.jpg&hash=face5f6ba91fe5774aa7af5fe65086312bc37631)
im usually seeing between 20 and 22psi on this gauge....that seems low to me
20psi is just over 1.4 bar
22 psi is almost 1.6 bar
:signLOL: thanks...but is that a good thing or bad?
Depends what boost the map is asking for, ask the person that mapped it
Awesome are now less awesome so not able to! Ill get her logged and see where i am from there
Reccomend ADS down on the docks buddy.....
TFSI gurus and nearest Revo chap fr 100 miles!
Where are you mate as I may be able to help out (time dependent)?.
In Preston, happy to travel though
