All Things Mk5 => Mk5 General Area => Topic started by: reflex11 on May 30, 2012, 02:43:45 pm
Title: grinding noise
Post by: reflex11 on May 30, 2012, 02:43:45 pm
I'm not sure what to call it but, this has happened since I had my new clutch/flywheel replaced I thought it would go away but it hasn't :jumping:
just wondering if any other fellow mk5 gti owners have this aswell, when applying gas just under the biting point sometimes there is a grinding noise like something is spinning its hard to explain but
when the clutch is fully disengaged it's not present, only when engaging, any help is appriecated because I think it's another trip the the garage just want some second opinions before getting fobbed off
 :driver:
Title: Re: grinding noise
Post by: B1NCC 1.8T on May 30, 2012, 04:35:01 pm
Had this before
Sounds like the thin plate behind the flywheel between the gearbox and engine has been bent a little.
Easy done when removing/fighting with a heavy 6 speed gearbox
The plate can usually be straightened ok with the gearbox still place.
Post by: reflex11 on May 30, 2012, 09:07:11 pm
dam are you sure? so another clutch job? more labour !! noooo
Post by: Dan.b on May 30, 2012, 09:17:20 pm
He said it can be fixed with the gearbox in place still  :happy2:
Post by: reflex11 on May 30, 2012, 09:18:56 pm
apart from the noise do you know if it causes any damage?
Post by: B1NCC 1.8T on May 30, 2012, 11:17:38 pm
If it is what I think it is, the plate just needs tweaked a little
Does no damage except scrapes the plate which you prob can't see anyway.
