All Things Mk5 => Mk5 General Area => Topic started by: suave on June 13, 2012, 09:25:04 am
I need to change the plugs in my standard 05 GTI but the price i just got from the dealers wasnt great.
Can I get OEM spark plugs from a motor spares shop as i assume they'd be a bit cheaper?
Can anyone tell me what type/make the standard plugs are for a GTI so i can get the right ones?
Stock plugs are a little cheaper from your local factors, but ebay always ends up being the cheapest.
NGK spark plugs,
better than oem - great price on ebay and brilliant reviews on this site :happy2:
Have a read on here!
http://www.mk5golfgti.co.uk/forum/index.php/topic,38720.msg460449.html#msg460449
This should help
For a non mapped GTI
NGK-BKR7EIX i belive are the ones required...
http://myworld.ebay.co.uk/timgreen880/?_trksid=p4340.l2559
From this seller!
Thanks guys.
Are the NGK Iridium ones ok for a non mapped GTI though??
Dealers in belfast want £12 for each one - bit steep...
yeah they're fine - im running them now
Hi Folks, sorry to interject, are we suggesting that a mapped Golf needs different spark plugs?
Andrew
just ones that run slightly colder - to be honest with you stage 1 and probably stage 2 and oem plugs will cope but then anything higher would probably most definitely need different plugs
ahhh ok, i hope so as im getting a Stage 1.5 (others call it 2) next Tuesday with R Tech....
Yeah you'll be fine - although to be honest for the sake of £20 you may aswell change them atleast then your running fresh sparks with your new map :happy2:
