All Things Mk5 => Mk5 General Area => Topic started by: Sammy on June 18, 2012, 06:34:17 pm
Title: Location of MAP sensor
Post by: Sammy on June 18, 2012, 06:34:17 pm
Anyone know where abouts this is located?
Title: Re: Location of MAP sensor
Post by: bacillus on June 18, 2012, 08:01:29 pm
It on the throttle body pipe...
Post by: Sammy on June 19, 2012, 12:05:18 pm
Has anyone got pics of how it looks like, The problem is i think I still have the golf R map sensor on as i forgot to tell the garage to replace that aprt from my old engine, Just want to know do i need to change it or can it be left as it is?
Post by: 56OctyVRS on June 19, 2012, 07:50:02 pm
If you look down the front of the engine where the throttle body pipe is. You will see the sensor location half way down the pipe on the right hand side.
The actual sensor looks like (click the link below)
http://www.micksgarage.ie/switches-sensors/map-sensor/audi/a3/a3/2003-onwards/2.0-tfsi/18358/ (http://www.micksgarage.ie/switches-sensors/map-sensor/audi/a3/a3/2003-onwards/2.0-tfsi/18358/)
The sensor fits into this pipe (click the link below).  You can see the area just above and to the right of the circular cap.
http://forums.vwvortex.com/showthread.php?5257206-FS-OEM-Audi-A3-Throttle-Pipe-MKV-2.0T-FSi-Noisemaker-Delete-Pipe (http://forums.vwvortex.com/showthread.php?5257206-FS-OEM-Audi-A3-Throttle-Pipe-MKV-2.0T-FSi-Noisemaker-Delete-Pipe)
