All Things Mk5 => Mk5 General Area => Topic started by: mad_pete on June 23, 2012, 06:01:19 pm
Title: Pirelli and standard GTI ride quality
Post by: mad_pete on June 23, 2012, 06:01:19 pm
Is the suspension set up the same ? Some say yes some say the Pirellis 15 mm lower like the ED30.
I want to get a pirelli but I like my comfort too :-)
Title: Re: Pirelli and standard GTI ride quality
Post by: RedRobin on June 23, 2012, 06:04:57 pm
I'm pretty certain that the Ed30 is not any lower at all than the Mk5 GTI ex-factory. And that the Pirelli suspension is the same as the Ed30.
Post by: berg on June 23, 2012, 06:06:02 pm
AFAIK Gti is the same as Pirelli/Ed30 - they are not lower, it is a misprint in some info
Post by: sub39h on June 23, 2012, 06:49:45 pm
i'd read somewhere they'd altered the suspension for the Ed30 but other members were quick to correct me. they carry the same part numbers apparently so should be the same  :happy2:
Post by: dan930 on June 23, 2012, 08:33:30 pm
I've also remember that I read from somewhere that the ed30 is slighty lower & harder ride
Post by: mad_pete on July 03, 2012, 01:25:19 pm
I've bought the Pirelli and it does seem a harder ride.  I noticed the recommended tyre pressures are 2,6 but for the stock GTI I think it was 2,4.
The Pirelli has Eagle F1 XLs on (SHOCK not pirelli's, I know)  and the GTI have Pilot Sport 3s on.
I haven't checked the tyre pressures yet and I guess the shocks have 20,000 less miles on them so might be a bit firmer.
Post by: Gene Hunt on July 03, 2012, 02:07:54 pm
No change to the ride hight on an ED30 or the Pirelli compared to the standard GTI. Both the ED30 & Pirelli run 18'' alloys as standard,so that might make the ride a bit harder.
Post by: Mandy on July 03, 2012, 02:14:37 pm
Congrats on your new car, how come you changed? I really liked your Monzas lol. :grin:
Post by: the bruce on July 03, 2012, 02:18:10 pm
GTI suspension = ED30 suspension = Pirelli suspension
The front springs differ between DSG and manual, the rear ones between 4d and 2d.
That's it. Same ride height, same stiffness.
BYD engines are faster than AXX/BWA > higher Vmax > increased tyre pressure. From
what I know all Pirellis came from factory with P Zero MO. At least all I've seen.  :wink:
Post by: mad_pete on July 03, 2012, 04:25:02 pm
Both cars are running 18" wheels.
Maybe it is the tyre pressures as not much else it can be.
I do like mine, but I wanted Xenon's and a bit more power
So when a Pirelli came up with some warranty, next service free and
16,000 less miles on it that seemed the best way to get those.
I wasn't sure about the wheels and the seats but in the flesh they look great.
Post by: mad_pete on July 06, 2012, 01:31:17 pm
Well checked the tyre pressures and they were at 2,7  I've dropped them down to 2,5 (standard GTI 2,4,  ED30 2,6)  and it's still a noticably firmer ride.  Seems to be picking out all the bumps in the round, much more than the standard GTI.  Maybe I'll swap the Eagle F1s to the PS3s maybe it's just a firmer tyre.
Post by: RedRobin on July 06, 2012, 01:43:36 pm
Filling your tyres with nitrogen will maintain consistent pressures for a considerable length of time.  :happy2:
Post by: Frenzy on July 06, 2012, 01:55:42 pm
Could be that there's slightly less give in the tyre wall of an Eagle F1, that it has a stiffer side wall in comparison to a PS3 - this would give a harsher ride as it would constitute unsprung mass even though it's not actually weight difference you are considering but never the less it is something going on below the suspension so therefore the suspension can not compensate for the way it affects ride quality.
The other factor would be the alloys but i'm guessing the Pirelli alloys weigh less than the Monzas, though that's not a given.
Post by: mad_pete on July 06, 2012, 05:50:04 pm
I was trying to think of clever ways I could look up the wheel weights but what I think I will do is go up to the garage take a wheel off each and lift them up. :-)
Post by: mad_pete on July 13, 2012, 12:00:58 pm
Going to swap the wheel + tyres tomorrow and see what difference that makes and also check the front spring rating.  Is there anything else I can check ?  I'll have them both up on ramps.
Is it possible something isn't set quite right on the Pirelli ?   If the parts are the same (springs, shocks, roll bars) I can't see where there is setup scope to make the ride firmer on the special editions over standard.
Post by: the bruce on July 13, 2012, 12:28:28 pm
There isn't any difference. Just the springs are matched and color coded for different weights of
DSG/non-DSG and 2-door/4-door.
I wish they'd have spent the ED30 and Pirelli an uprated suspension with stiffer springs, dampers,
top mounts (like Cupra, RS3) and bushings (like Cupra, S3, RS3), but they have not.
If you really feel a difference you feel different tyres, different tyre pressures, different tyre wear
and suspension wear.
Post by: mad_pete on July 14, 2012, 02:54:17 pm
Yep springs the same colour codes all round.  Swapped the wheels over today and drove the Pirelli on both.
As they were off and I was near a scale we popped them on -   Monza IIs with tyre 24 .5 kg    Pirelli Alloy with tyre 22.5 KG  (roughly)   and my W rated PS3s are a better ride the Y rated eagle F1s (with rim protector).
I found the PS3s take the edge of bumps more. Things like bridge joins aren't as harsh.  The rest of the ride is simliar but I think it's that raw jolt that is taking the edge off the ride.
I will probably swap them onto the Pirelli wheels at some point.
The rest as stated is probably due to suspension wear so good case for refreshing the suspension parts on a higher mileage car.   Pirelli has done 33,000 and the standard 50,000
I was surprised how ordinary the car looks without the special edition alloys on so popped them back on sharpish.
Post by: flashp on July 15, 2012, 11:43:12 am
I did a colour change on my Pirelli's. Made all the difference on a silver car. I was on the point of buying new wheels, but not now!
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi326.photobucket.com%2Falbums%2Fk438%2Fflashp%2Fnearsideview.jpg&hash=9bc980d23e8e950e5e05b882f985b5bf1fbbbd41)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi326.photobucket.com%2Falbums%2Fk438%2Fflashp%2Fsinglewheel.jpg&hash=fbecff25ad04f1ed4fafed6511ab76336a56566e)
Post by: Tortaruga on July 15, 2012, 12:26:37 pm
Very smart sir! Lovely car, lovely wheels, although I think they're an acquired taste.
Post by: flashp on July 15, 2012, 03:25:54 pm
Thanks. Took me a while to find the 'P' in the design also!  :signLOL: It's stairing you in the face when you know though.
Post by: mad_pete on July 15, 2012, 04:05:27 pm
Photos of the wheels don't do them justice. The dog leg on them looks great from other angles
Post by: Mandy on July 15, 2012, 04:29:12 pm
Wow, colour of the wheels goes really well with the silver car. :happy2:
