All Things Mk5 => Modifications & Technical Area => Cosmetic/Interior Modifications => Topic started by: berg on July 07, 2012, 10:12:48 pm
Title: Help retrofitting MFSW and Highline...
Post by: berg on July 07, 2012, 10:12:48 pm
Hi guys, I want to get the above sorted soon on my manual ED30.
Think am going to get the wheel brand new from VW about £400.00, and need a steering wheel controller too i think. Are they about £115.00?
How much is a Highline dash if cant pick up a suitable one on here?
Do I need any other parts to integrate the above with my blutooth/510/MDI?
ta
Title: Re: Help retrofitting MFSW and Highline...
Post by: vw55raz on July 07, 2012, 11:04:24 pm
I'm selling a highline cluster.
http://www.mk5golfgti.co.uk/forum/index.php/topic,49687.0.html
Post by: olsen-72 on July 07, 2012, 11:38:13 pm
You will need also a different wiper stalk coz you dont need your buttons any more. Possibly new slip ring (depends what type u have now). VCDS and VAG Commander if u dont get SKC for ur clocks
Post by: berg on July 09, 2012, 09:59:07 am
Thanks, can I tell if need a new slip ring by looking at the VCDS scan? RAZ have pm'ed you.
Post by: olsen-72 on July 09, 2012, 10:08:57 pm
There is no info on the scan.
Title: Re: Re: Help retrofitting MFSW and Highline...
Post by: jason_rmh on July 10, 2012, 06:41:57 am
If you get the part number of your existing Steering wheel control module from the vcds scan then check here on the Ross tech page which should tell you which slip ring is fitted with that module.
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions (http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions)
You can also use that page to check your existing slip ring is compatible with your new module.
When fitting my mfsw I fitted a CH module which gives the option of using a .mk6 steering wheel also if you fancy a change later on.
Jas
Post by: olsen-72 on July 10, 2012, 04:46:52 pm
This list for the Steering Wheel Controler which u can easy find in VCDS scan. But you cant find the slip ring part number on that scan
Title: Re: Re: Re: Help retrofitting MFSW and Highline...
Post by: jason_rmh on July 10, 2012, 07:42:54 pm
True although the list will give a guide to what *should* be fitted but I guess the only real way to tell is take off the steering wheel and take a look.
Jas
Post by: berg on July 19, 2012, 10:24:44 pm
so can you get the SKC code from VW if you dont have it?
re wiper stalk do you have to change it or just sesirable to do so?
ta
Post by: Greeners on July 19, 2012, 10:29:33 pm
ta
Makes no difference whatsoever so an unnecessary expense.  :happy2:
Post by: olsen-72 on July 19, 2012, 10:50:48 pm
I doubt it hehe. But I may help doesn't matter which year the clocks are. PM me if u want
Post by: berg on July 19, 2012, 10:59:00 pm
[/quote
ok will bear in mind, thanks  :happy2:]
Post by: jason_rmh on July 22, 2012, 11:37:24 am
ta
If the highline clocks are the earlier type you can use a vag commander tool to get the skc and do the swap.
If later (ending 974b I think) they have extra security making the swap difficult with a used cluster.
However.... if you get in touch with Kalu on here, he can do it for you. He did mine. He's down in Hemel Hempstead but worth the drive!
When I upgraded mine I left the wiper stalk.
Hope this helps.
Jas
Post by: Obbzi on August 01, 2012, 08:24:39 pm
How easy of a job is this to do? I have every option apart from MFSW and hi-line dash. If I get someone to do it how much roughly do you think it would be?
Anyone know anywhere in the NW that could do it?
Post by: vw55raz on August 01, 2012, 08:39:37 pm
Depends on what year car you have and what clocks you currently have.
Post by: Obbzi on August 01, 2012, 09:31:00 pm
2007 Golf GT TDI 170 think its a lo-line dash?
Post by: berg on August 01, 2012, 10:05:48 pm
i am in north west mate, you need to speak to Kalu. Either drive to him, like I will be or post your clocks and keys but means doing without your car and worrying whether courier will lose/break the clocks
Post by: Obbzi on August 01, 2012, 10:16:10 pm
Cheers will look into that  :happy2:
Post by: nadlad on August 02, 2012, 02:08:14 am
Ave got a mfsw and airbag for sale 230 delivered or nearest offer cheers
