All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: roohunt27 on July 18, 2012, 10:48:46 am
Title: RCD 300 in 05 MK5 GTI - Any sort of AUX in solution
Post by: roohunt27 on July 18, 2012, 10:48:46 am
I've recently bought an 05 mk5 GTI - I love the car but can't believe what a mare getting an aux in solution for the standard stereo is, I took it to VW as I found this on the website:
http://www.volkswagen.co.uk/owners/accessories/technology/1K0998940/aux-in-socket-retro-fit?mark=golf-2004-2009&previousCategory=technology
They're telling me they can't fit that to my stereo (RCD300) as it's not compatible, they can however fit a much more expensive ipod kit (£150 fitted) i'm not interested in this, not because of the cost, but because apple are highly likely to change the ipod connection at some point and then this kit will be useless... Plus I just want to get the audio out of my iphone and through the speakers, I don't want to control it / charge it through the head unit - That stuff never works as it should and is frustrating to use.
I'd happily upgrade the stereo to a newer VW model but i've read lots about all this canbus stuff and as mine is one of the older gtis i'd imagine it has the older stuff going on back there. I can't even put a different stereo in without faffing with the fuse board, the last thing I want to do. Basically i'm looking for the absolute minimal fuss option to get a aux connection into my stereo - Can I buy an MFD2 sat nav and do a straight swap as they have an aux interface from the looks of it? Or will that require faff with the CANBUS - I know the sat nav is rubbish but I don't really care, I just want to play music through the speakers without using one of those terrible fm transmitter things! I'd settle for putting a tape deck in if they'd ever had one in the mk5. Will one of these work? Or is it pot luck?
http://www.ebay.co.uk/itm/VW-PASSAT-GOLF-MK5-AUX-IN-TO-MP3-IPOD-LEAD-CT29VW02-/280792847317
Any help or advice would me much appreciated,
Andy
Title: Re: RCD 300 in 05 MK5 GTI - Any sort of AUX in solution
Post by: GLIDN on July 18, 2012, 11:30:59 am
I can happily report, the rcd310/510, plus mdi charges iphone and works extremely well all controlled from the radio.
I very much doubt Apple will be replacing the apple connection anytime soon. As they have way too many OEM ipod equipped cars these days.
Only way i know that works kind of is a grom unit i think it's called
Post by: roohunt27 on July 18, 2012, 02:23:06 pm
Cheers for your reply GLIDN - Doesn't the 310/510 result in some sort of battery drain issue though? and will I need to faff about getting it plugged in at a dealer? Also is it one of those situations where you have to set up 6 playlists to replicate the cd changer?
Post by: rich83 on July 18, 2012, 02:24:53 pm
I bought a 3.5mm jack aux connector off ebay... worked a treat!
Post by: roohunt27 on July 18, 2012, 02:25:59 pm
Richwig is your stereo a RCD300 and any chance if you get a sec you could link me to the item you bought?
Post by: rich83 on July 18, 2012, 02:34:28 pm
It was in my old car.
It was similar to this one... http://www.ebay.co.uk/itm/Car-MP3-Player-Radio-Interface-Aux-in-Adapter-For-V-W-RCD-200-RCD300-RCD-500-/280879201260?pt=US_Adapters&hash=item4165b47bec#ht_3771wt_1024
Post by: roohunt27 on July 18, 2012, 02:39:57 pm
Nice one, exactly what i'm after - and did it need any extra configuring of the stereo to make it realise there was an aux in? Or just press the cd button twice and you have sound?
Sorry for all the questions, want to make sure i'm buying the right bit.
Post by: rich83 on July 18, 2012, 02:46:16 pm
Yep... press the CD button twice. make sure you ground the "ground"cable too... thats very important!
Post by: roohunt27 on July 18, 2012, 02:53:25 pm
Thanks again, really appreciate the help.
Just a couple more questions, where did you ground your ground cable when fitting and where did you have the cable run to? Is there a gap anywhere i can come through or will I need to be removing more bits to make it accessible?
Post by: rich83 on July 18, 2012, 02:55:47 pm
I ran the cable into the glove box... not a 30second job but its possible... i think i used a metal coat hanger to guide it.
I earthed it on the retaining scree for the radio.  :happy2:
Post by: roohunt27 on July 18, 2012, 03:15:03 pm
Cheers richwig, excellent information, really appreciate your replies.
Post by: JoeDarKa on July 19, 2012, 06:28:43 pm
Will that work with the RNS510??  :rolleye:
Post by: GLIDN on July 20, 2012, 08:19:34 am
no, you have all your playlists and song, podcast etc.
Unless you have a gateway older then L you will have drain issue. for Eddie-NL selling configured gateways for about 70-90 there is an rcd310 in for sale section 55, MDI can be had around 80-150.
The radio upgrade alone is worth it. Aux kit for rcd310 is only around a few quid from vw too.
Post by: rich83 on July 20, 2012, 08:29:16 am
The rns510 requires a slightly different cable but yes it's possible to add an aux.
Post by: adminkatana on January 17, 2013, 11:48:21 pm
Sorry to post in an old thread, but this is the first time I've seen the iPod/ iPhone CD Changer cable posted for use with the stock Head Units.
I have an RCD 500 in the car, seeing as the 6 CD Changer is built into the Head Unit, will this cable still work for me?
Also, how difficult is it the actually route the cable into the glovebox? Do you need to cut anything? Or just guide it through with a coat hanger as you mentioned above?
Thank you again for your help!  :smiley:
Post by: rich83 on January 18, 2013, 12:20:13 am
Correct... you dont need to cut anything.
Post by: DamoP on January 18, 2013, 07:13:00 am
Another option for a simple fit is the Volkswagen iPod adaptor for people not wanting to change their head units
Post by: adminkatana on January 18, 2013, 08:07:50 am
Great, thank you both for your help!
I'll order one of those cables shortly. Well, I would love a new Head Unit, but I've got Service and Tyres that need doing coming up! Hopefully in the future though.
Post by: paulw123 on January 18, 2013, 01:16:23 pm
my car came with an rcd300 (mp3) with a parrot 3100 hands free kit fitted.
Can i fit this as well?
Does the parot kit plug into another socket on the back of the headunit?
Post by: MrDo on January 18, 2013, 08:19:47 pm
I used this kit at add aux input to the rcd300 that came in my 06 GTI.
http://www.dynamicsounds.co.uk/connects2-ctvvgx004-vw-eos-golf-passat-polo-jetta-aux-interface-adaptor-p-8770.html (http://www.dynamicsounds.co.uk/connects2-ctvvgx004-vw-eos-golf-passat-polo-jetta-aux-interface-adaptor-p-8770.html)
Connects 2 Aux Input to OEM Adapter Interface for VW Passat/Golf/Touareg/Touran/Transporter with Delphi, Blaupunkt, Delta 6 Double Din,RCD200,RCD300,RCD500 head units. This Aux Adaptor Interface is compatible with following car models:
 VW Eos         (2006 onwards)
 VW Golf        (2003 onwards) MK5
 VW Passat     (2003 onwards)
 VW Polo        (2004 onwards)
 VW Jetta       (2006 onwards)
 VW Touareg  (2002 onwards)
 VW Touran    (2002 onwards)
 VW Transporter (2002 onwards) T5
Please note: This item is NOT compatible with stereos that have the 6 CD Player built into the stereo.
I actually used a longer phono to 3.5mm cable (cheap on ebay etc) so it can reach to my iPhone suctioned to my windscreen running the tomtom app and playing music. When I do this the cable can runs between glove box door without any stress to it as cable is relatively thin and its tucked away the rest of the time.
Fitting took approx 45 mins. No need to cut anything.  The aux cable can be feed by hand across to the glove box, just make sure you remove the owners manual and you should be able to see the cabe and pull it in to the glove box.
Lots of videos showing how to remove radio on YouTube.http://youtu.be/Ea8nos5SbLw (http://youtu.be/Ea8nos5SbLw)
Have clean cloths/rags to protect your gear knob etc from scratches.
I did buy plastic trim tools on eBay. I took things slowly, watching each step on my ipad before proceeding. Take it slow and don't force anything and you'll be fine. I also put sound deadening tape on the box and wires to avoid vibrations and rattles.
I plan to upgrade the head unit to RNS 510 or 310 but this aux input has worked a treat on continental holiday drives over the summer etc.
Good luck :drinking:
Post by: Allanmmac on June 19, 2015, 10:25:25 am
Hi all
New to the forum, just bought a mark v GTI with an RCD 300 unit and a 6cd changer in the armrest.  Really want to be able to play all my music, stored on an old iPhone 4, through the stereo.
Is the aux in linked to below the answer? All seems away complicated. Could have a conversation with the boys in Halfords bu don't want to get stung if there's a reasonably simple solution I'm not aware of.
Thanks.
Andy
Post by: shoaybmakda on June 22, 2015, 08:59:04 pm
Hi @Allanmmac (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=13215) you could get a iPod kit to replace the cd changer in your armrest. The MDI kit won't work with the RCD 300. The iPod kit you can use won't charge your iPod which is the most annoying thing. If you did want to use the MDI kit which does charge your iPod you will need to update your head unit and your CAN to stop the battery drain issue. Something like this should work for now:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fa1%2Fbaz_doc%2FImage0037.jpg&hash=c4203580d0dec0b317217f9ce91d4492acfb105a)
Post by: dannydub on November 25, 2017, 11:29:26 pm
Hi all,
I have an RCD300 with the inbuilt 6 CD changer.
What cable or setup do I require so I can use my iPod through the standard headunit?
