All Things Mk5 => Mk5 General Area => Topic started by: nadlad on July 25, 2012, 12:04:10 am
Title: full fis clocks coding
Post by: nadlad on July 25, 2012, 12:04:10 am
Hi would these clocks fit my 08 gt sport 140  at the moment it has half fis the part number fo the new clocks is
1ko 920 971C they were petrol but have been changed to diesel foils he has the skc for the clocks and i have the skc for my clocks too is it straightforward?
cheers
Title: Re: full fis clocks coding
Post by: olsen-72 on July 25, 2012, 01:04:27 am
If u have a both SKC than all the work can be done with VCDS. Just follow the Ross Tech procedure for Cluster swap.
Post by: vw55raz on July 25, 2012, 03:40:33 am
Hi mate that's me sellin them  :)
I'll code them for you too.
Post by: nadlad on July 25, 2012, 08:42:14 am
Your needles buggered though
Post by: vw55raz on July 25, 2012, 10:49:11 am
The needle is fine. It's the rev face which is a Tdi one. It should be a petrol one. If you put a petrol one on it then the revs will be accurate.
Raz
