All Things Mk5 => Mk5 General Area => Topic started by: nadlad on July 26, 2012, 04:33:59 pm
Title: Full fis clocks tps?
Post by: nadlad on July 26, 2012, 04:33:59 pm
I rang my local dealer today for some highline clocks they quoted 296 inc vat plus a 115 pound surcharge as its a exchange product and I'll be exchanging half fis fit full fis!
Does anyone know the correct part number of highline clocks for a MY2008 gt sport diesel 140?
Title: Re: Full fis clocks tps?
Post by: Matto on July 26, 2012, 04:46:25 pm
Do you know the part number for the clocks you have in at the minute?
Post by: nadlad on July 26, 2012, 05:09:03 pm
They are 1ko 920 964 b
Post by: Matto on July 26, 2012, 05:25:57 pm
From memory that is the same as I had before swapping to highline so you will want a set ending in 974B. I had mine coded and fitted by Kalu off here.
Post by: apples12 on July 26, 2012, 06:10:12 pm
Nadld, you can get them for away cheaper and get them coded by Kalu...
You may want to confirm With tps as I'm pretty sure that when doing exchange, the surcharge is dependent on exchanging like for like (per part number)...and not very many dealers will code these in for you either...
You've got a pm about a set of clocks, contact Kalu or Olsen about coding  :happy2:
Post by: nadlad on July 26, 2012, 06:54:21 pm
Olsen wild be closer as am in York do u have his proper username?
