All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: dan930 on July 28, 2012, 01:44:27 pm
How come I don't see anyone changing the manifold for a aftermarket one???is it that the oem design is very good??
Little point if using with an oem turbo unless you're using water meths and the manifold has pre-drilled ports.
Inlet or exhaust manifold?? :grin:
