All Things Mk5 => How to Guides / Troubleshooting => Topic started by: johnhol78 on July 31, 2012, 05:39:12 pm
Some help needed if possible. The CCM on is worrying me :confused:
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0004738
Shop #: WSC 01279 785 00200
VCID: 40845C846A05
1 Fault Found:
01309 - Power Steering Control Module (J500)
008 - Implausible Signal
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000002016266
Coding: ED8C8F27000418000A1600001400000000197F075C
Shop #: WSC 00200 210 90001
VCID: 2B5E1B28F383
Part No: 1K2 955 119 C
Component: Wischer VW350 012 0402
Coding: 00065493
Shop #: WSC 00200
Part No: 1K0 955 559 R
Component: RegenLichtSens 010 1010
Coding: 00207646
Shop #: WSC 00200
2 Faults Found:
00987 - Lamp for Brake Light; Left (M9)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 212
Mileage: 129911 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.70 V
ON
ON
OFF
OFF
OFF
01330 - Central Control Module for Central Convenience (J393)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 224
Mileage: 130625 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.70 V
ON
ON
OFF
OFF
OFF
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K6 920 962
Component: KOMBIINSTRUMENT VDD 1012
Coding: 0001403
Shop #: WSC 01019 210 75693
VCID: EED8523C8011
1 Fault Found:
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0192
Revision: H16 Serial number: 2500K0820400AB
Coding: E9807F065002020003
Shop #: WSC 06314 000 00000
VCID: 346C00542EBD
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 2
Reset counter: 212
Mileage: 131290 km
Time Indication: 0
Date: 2000.00.00
Time: 17:25:59
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2370
Coding: 0000692
VCID: 36683A5C38C1
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2429
Coding: 0000144
VCID: 336E03482BB3
1 Fault Found:
00934 - Electric Window Motor; Rear Left (V26)
This could be expensive :confused:
have you tried clearing all faults and rescanning?
looks like most errors are in fact pointing to the cccm
Yeah, cleared the codes and this was left.
CCCM, is that a easy part to replace or should I be going to the dealer?
you could get a 2nd hand one and fit yourself.
heres a guide how to change it on this post somewhere
http://forums.vwvortex.com/showthread.php?3604801-DIY-hi-line-cluster&s=0779cba71b261abc7957376722d9ad5e
