All Things Mk5 => Mk5 General Area => Topic started by: ConeKiller on August 02, 2012, 11:46:12 am
My girlfriend has a 2006 plate Eos with a problem :sad1:
It has the standard xenon lights that turn with the steering and a seperate bulb that lights up when you turn round a tight corner.
The passenger side dipped and main beam has now failed, which I guess is the same bulb possibly??
The lights that turn have also stopped on the other side, and the kurb lights have stopped working, however the side lights and indicators still work...
I have replaced the bulb on the passenger side which has not cured the problem, and I have checked the fuses which are all fine in both fuse boxes!!
Would I be correct iin saying its the ballast? If so does anyone know a part number or how to fix the problem... If its not the ballast does anyone have any idea of what the problem could be?
Thanks in advance guys!!
