General => Detailing => Topic started by: heady2010 on August 07, 2012, 07:52:38 pm
Just bought myself the das6 pro polisher and just wanted to run through the steps i was going to take, please criticise where appropriate:
wash and clay first, i have the meguires pads, cut, polish and finish, and using auto finesse rejuvenate, start with finishing pad to see if correction is gained and change pad accordingly, starting slow speed, with just the weight of the machine-2 passes, then up to speed 3/4 with moderate pressure-4 passes, and repeat slow speed stage, then wipe off. Then using black hole as a glaze, im assuming just a finishing pad required for this? was going to use speed 3/4, just unsure on how many passes and what kind of pressure to use?
cheers
Some very good guide son you tube to watch, would alway sdo as much home work as possible before you start. Preparation is the key.
