All Things Mk5 => How to Guides / Troubleshooting => Topic started by: mrbeck on August 07, 2012, 08:27:19 pm
Got a noise coming from the engine bay on start up which sounds like a fan making contact with something it shouldn't. Only lasts 2-3 secs and then stops. Have ha a look under the bonnet, but can't see anything which looks out of place or damaged. Any ideas?
Is it followed by an electrical high-pitched whine?
This is the electronically-controlled throttle self-calibrating, nothing to worry about :happy2:
No, definitely not that I'm afraid. Had the car nearly three years now, and this is definitely a new noise.
Was told on another forum that it might be a sticking starter motor? Not sure how likely that is.
It could well be the starter motor or solenoid. Mine does the same thing. Can you post a sound clip?
Will try to get one for you...
Problem is it doesn't happen every single time. Probably 1 in every 3 starts.
