All Things Mk5 => Mk5 General Area => Topic started by: B1NCC 1.8T on August 22, 2012, 06:04:09 pm
Title: Lowering a Mk5 ED30 with factory Xenons
Post by: B1NCC 1.8T on August 22, 2012, 06:04:09 pm
Im looking into fitting H&R or Eibach sportline springs to my ED30
I'm wondering what you guys do to overcome the xenon adjusters on the wishbones etc
Or does lowering the car not affect them
I remember seeing a mk5 a while back which was lowered and the xenon adjusters were not working due to the ride height
Any help would be appreciated.
Title: Re: Lowering a Mk5 ED30 with factory Xenons
Post by: RedRobin on August 22, 2012, 06:09:22 pm
I didn't do anything regarding my Xenons (Mk5 GTI) when I lowered (KW V3). I have 95mm road clearance at lowest point under the car.
It has passed MOT at least 3 times since lowered.
Post by: sub39h on August 22, 2012, 06:11:54 pm
on the 8P they can be recalibrated
Post by: Shabba168 on August 22, 2012, 10:12:55 pm
They just need to be readjusted with vagcom after its done
Post by: B1NCC 1.8T on August 22, 2012, 10:29:45 pm
Thanks for the replys guys
I just wondered if the actual adjusters them selves would get damaged/bent once the car is lowered with the wishbone being pushed upwards
Post by: JamesG on August 24, 2012, 02:28:19 am
Keety mines seems fine after i fitted the H&R's more than welcome to have a gander
Post by: higher1 on August 24, 2012, 07:11:15 am
I have factory adjusters and they work fine after fitting eibach springs I now run alot lower on h&r coilovers and they still work fine
Obviously disconnect them before fitting the springs otherwise they will get damaged
Post by: Hedge on August 24, 2012, 08:13:59 am
I don't think so.
Post by: neg on August 24, 2012, 11:06:25 am
I reset mine using VCDS as they were pointing up - did some kind of reset and they adjusted themselves and were fine from then on.
