All Things Mk5 => Mk5 General Area => Topic started by: jsklair on August 29, 2012, 11:53:44 am
Title: Idling Problem - PCV or DV at fault??
Post by: jsklair on August 29, 2012, 11:53:44 am
I was driving around on Monday, and I was thinking the exhaust note seemed a little hoarser than usual.  I thought it was my imagination playing tricks on me.
Later that afternoon, the idle started to stutter up and down.  Going from about 900rpm to 800rpm and back again, over and over.
The engine sounded like it was skipping a beat every second or so too.   And it also now seemed to be physically juddering (slightly) in the engine bay.
I drove home, and haven't used it since.
I searched through the forum, and the two main problems it could be seem to be either the Diverter Valve, or the PCV Valve.
But I'm still not sure which!  Base on what I've written, what do you all think the problem actually is?
Thanks in advance.
Title: Re: Idling Problem - PCV or DV at fault??
Post by: E30Dom on August 29, 2012, 01:40:51 pm
More likely pcv at idle, have you done the old remove the dipstick trick to see if engine note changes?
Post by: jsklair on August 29, 2012, 02:11:28 pm
Cheers E30DOM, I'll give it a go tonight.
As it's already juddering, what should I expect to happen when I remove the dipstick?
Post by: E30Dom on August 29, 2012, 03:06:34 pm
Either get worse or nothing at all...
If gets worse then PCV might be ok, if stays the same it might be the PCV failed...
It could be a number of other things, so after you've done this test and reported back, it could need scanning for faults... could be plugs/coilpacks...
Post by: jsklair on August 29, 2012, 04:38:56 pm
Will do.
I'm going to the Paralympics Opening Cermrony now  :jumpmove:, but I'll do a late night mission when I get home.
Thanks for the help.
Post by: E30Dom on August 29, 2012, 04:50:31 pm
Oooo nice one, enjoy!
Post by: jsklair on August 30, 2012, 06:18:19 pm
I did the dipstick test, and I couldn't sense any discernible change in the juddering.
Does that mean it's most likely the PCV?
Regarding the coil-packs, I had them changed as part of the recall a couple of years ago.
What does everyone think I should do next?
BTW, the Paralympic Opening Ceremony was awesome!  :happy2:
Post by: jsklair on August 31, 2012, 04:27:35 pm
Any opinions?
I'm going to pick up the PCV tomorrow from my local stealer; and have a bash at doing it myself.
I have a hammer, and a temper.  Should be easy.
But any advice would be appreciated.
Post by: Tortaruga on August 31, 2012, 04:42:28 pm
If the car didn't start to rough idle with the dipstick out it's most likely a failed PCV.
Here's a DIY replacement guide:
http://vagdrivers.net/forums/index.php?showtopic=40537
Post by: h4rdy on August 31, 2012, 04:57:35 pm
Any opinions?
Use the hammer and temper first always works :signLOL:
Be careful removing the engine cover it breaks.
Dead easy though 4 TORX screws so make sure you have TORX bits and don't tighten too much as it strips the plastic.
Oh and make sure you have the correct revision for your car. N or P I think. P for later cars with the rear checkvalve.
If it doesn't work you have the wrong one.
Post by: jsklair on August 31, 2012, 05:11:54 pm
The car was already rough idling.  Taking the dipstick out made no change.
Is that the same?
Thanks for this H4rdy, but it's all a bit Greek to me.  I have a 2005 car.  Does the PCV come as either a "N" or a "P"?
No idea about the rear checkvalve. Anyway for me to check?
Thanks to you all for your help thus far!  :drinking:
Post by: SteveS on August 31, 2012, 05:19:02 pm
I have exactly the same problem.
I bought a REV N PCV and will be replacing it this weekend (i hope) £32 delivered
Post by: jsklair on August 31, 2012, 05:31:47 pm
Hey Steve, how did you know you needed an "N"?
And where did you order it from?  Cheers.
Post by: Saintsteve on August 31, 2012, 05:33:48 pm
your dealer will sell you the compatible Revision... I think it should be N for your K03 . It now has 2 check valves in the housing rather then the one only previously. Rev P is for the later cars.
Post by: jsklair on August 31, 2012, 05:39:50 pm
Cheers.
Should I buy the gasket and hoses too as a matter of course?  Or only if they are worn?
Post by: 56OctyVRS on August 31, 2012, 07:43:35 pm
The gasket and hose will be fine. Just wipe off the old oil residue and reinstall. The torx screws only need to be finger tight. Start from the right handside when tightening and move to the left. That will ensure it seats correctly.
Post by: SteveS on August 31, 2012, 07:47:58 pm
I asked on here and the company i bought the valve from told me the same..
I can give you the contact details if you like. Im sure it will cost you more than £32 from the dealer.
Post by: jsklair on August 31, 2012, 08:13:23 pm
Hey steves, yeah, I'd appreciate it you could let me know the company details.
Cheers.
Post by: jsklair on September 01, 2012, 11:38:44 am
I've just been told by a dealer that "L" is the latest version.
Is that true?
Or should I look elsewhere for an "N"??
Post by: 56OctyVRS on September 01, 2012, 12:44:19 pm
The N replaced the L, as that version is about 2 years old now. Have you a local TPS centre near to you? If so I would give them a phone call.
Post by: SteveS on September 02, 2012, 08:45:44 pm
Just replaced mine today.
The valve itself seems ok, (sucking test ;)) however, i saw once it was off, it was lose and the bottom had oil platters.. so im not sure it was creating a seal.
It didnt come with the rubber gasket for between the two bits, so im going to get one of those too if things dont improve.. i think mine has deteriorated a tad
Post by: SteveS on September 02, 2012, 08:47:53 pm
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi.imgur.com%2FaO4t0l.jpg&hash=2cfc1c07b78a23356f0acafd7110d8e667c2804e)
Post by: 56OctyVRS on September 03, 2012, 01:23:13 am
The gasket looks fine from what I can see. They very rarely need replacing.
Post by: micky 32 on September 03, 2012, 02:04:17 am
I just replaced my PCV with the N and i didn't change the gasket and no leaks, all ok.
Post by: jsklair on September 03, 2012, 03:00:14 pm
Cheers SteveS and everyone else.
I'm going to get the "N", and keep the existing gasket.
I'll keep you all updated.
Post by: SteveS on September 03, 2012, 03:02:23 pm
The one I took off. Was perfectly fine. Think the bolts were lose. Hm never mind
Post by: Saintsteve on September 03, 2012, 04:03:08 pm
I changed mine as it had black carbon deposits all over one of the circular seals which would indicate a blow or leak past.
idles much smoother now.
