All Things Mk5 => Mk5 General Area => Topic started by: scopes on August 29, 2012, 11:53:19 pm
Hey All
Would it work ok, Fitting an S3 cooler to a Forge FMIC thats already fitted...
Or
would there be new pipes required
How much different would that be with the fittings over the standard cooler?
Could you get away with a slight adjustment to the forge pipe work
thanks
Scopes
Unfortunately and afaik you will need the Forge S3 twintercooler hoses (hoses 296 and 297).
Cheers bacillus there about 200 quid if i remember right
I explored this a couple of years back and iirc the hoses were only around £125ish. I would give Forge a ring to confirm a price.
