		All Things Mk5 => Mk5 General Area => Topic started by: Baz300 on September 17, 2012, 05:25:49 pm
				I had my car in for a 4 wheel alinment today
 When I picked the car up they told me that there was not enough adjustment in the driver side ball joint to get the camber 100% but it should be fine.
 On the way home the car is pulling to the left and the steering wheel is slightly off center to the left
 I phoned the garage to tell them about them and they are saying that it is doing it because they couldn't get the camber 100% on the driver side
 Can anyone offer some advice? Would the camber make the car pull to the left? or have they just done a bad job of it?
 Not too happy as I have paid £90 to get the alinment done
 I think that they should have contacted you as soon as they saw on the alignment machine that there wasn't enough adjustment possible. Your car "is pulling to the left and the steering wheel is slightly off center to the left" is absolutely not fine and they have wrongly taken your money in my opinion.
 They should have offered to fix the ball joint problem first (obviously charging you for it) and then aligned it properly.
 At the moment you are driving a car needing alignment and if left it could lead to other problems.
 I'm not too happy about it
 The ball joint they can't get the adjustment on is brand new and was fitted by a garage that I trust
 What does the garage that you trust think of the people who 'did the alignment'?
 I would firstly tell the alignment company that you are very dissatisfied and why (can you cancel your payment?)...
 Tell the garage you trust that there appears to be a problem with their ball joint installation and tell them what the alignment company found...
 Get the trusted garage to put it right (within their original charges)...
 Go back to the alignment people and ask them to do the job properly and you'll be happy to pay them properly.
 Be polite but firm and ask all those concerned to please understand your point of view. Tell us what happens please  :happy2:
				I'll phone the garage that done the ball joint tomorrow
 I couldn't scan the printout because it was so faint but have made a mock up of the figures here
 (https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi760.photobucket.com%2Falbums%2Fxx242%2Fbaz300%2F8efbcfe6abc5419ed7bc43e8e39ef549.jpg&hash=0e23d2c1614a049649888fbfea52e4bc2518c6c2)
 Does anyone understand that? The full stop is the degree sign
				That's terrible.   :surprised:
 I'd contact the garage, get the ball joint sorted and complain (in a friendly way) then demand a free wheel alignment with the company that did it the first time. Cannot believe they did it, absolutely bloody pointless doing it on the car IMHO.
 Good luck bud!
 Sounds to me that the alignment company is happy to take advantage. Perhaps the senior management of that company might take a better view and the fault of telling you it was ok was down to the operator.
 Contact the top guy in both businesses.
				Why was the ball joint replaced, not a common fault on a mk5. Did you hit an pot hole or something.
 Even though the adjustment is on the ball joint, could be something else out of line causing the problems.
 I sheared one of the studs when I went to fit my suspension kit so had to get it replaced, I also had to replace the track rod ends on both sides and the car was pulling to the left with the steering wheel off center exactly the same as it is now after changing the track rod ends
 ....Does that mean that you did this work yourself?
 I done the back suspension and the front passenger side
 I had the problem with the ball joint on the driver side and one of the top mount bolts was just spinning on the driver side so I had to get the car trailerd to the garage for them to sort the driver side and ball joint
 They also checked over all the work I done and said everything was perfect
 ....Good. So at least that means that you haven't done something potentially detrimental for which you would have to take the responsibility.
 I'm sure your trusted garage will understand your predicament and help you resolve it. The fact that the alignment company were happy to charge you without completing a proper job suggests that they may be more awkward and that's why I suggest a calm chat with their boss.
 Did your trusted garage recommend them?
 No they recommended a different place but They couldn't get my car in for at least 4 weeks and I didn't want to wait that long as I need my car every day.
 They were the only other local company that I could find that that offerd a 4 wheel alinment all the others were tracking only
				Are they trying to adjust camber on the front or rear?
 Didn't think it was possible on the front...  :confused:
 The front I assume as they are blaming the ball joint not having enough adjustment for the camber
				Stock hubs and wishbones?
 If so, the only camber adjustment is a by product of the toe position unless the subframe is moved slightly to centralise things. To my knowledge it is only the TT wishbones that are designed for camber adjustment.
 What are your tyres like on the front? Uneven wear can cause "pull".
 Don't front top mounts also allow camber adjustment? Though it would seem to be unlikely that this car has been fitted with them.
				Normal front top mounts don't allow camber adjustment.
				Yeah everything is stock bar the shocks and springs (bilsten and eibach) and its new strut top mounts all round too
				The tyres are all like new (only coverd 4000miles on them and no uneaven wear)
 So should they not of touched the bottom ball joint nuts? And left them to the factory torque specs?
 ....Sorry, I should have given more information  :ashamed:. I meant the aftermarket top mounts such as by KW and Ground Control.
				Baz, just out of interest who done your alignment?
				For all that's in the camber I can't see it being the cause of it pulling, in my experience a car pulling is due to incorrect toe.
 Sent from my HTC One S using Tapatalk 2
 Overton
 Overton
 ....Is Overton the name of an accredited alignment company or just a town?
 So, who have you now spoken to and what's the latest in sorting out your problem?
				Overton is the name of the garage that done the alinment.
 I spoke to the garage that done the bal joint and they said that it is is not adjustable and should only be set to the correct torque.
 I dropped the car off to them this morning and asked them to just torque the ball joint nuts to VW s spec as the camber is not adjustable on a mk5 golf. And to check the toe is straight. The boy wasn't too happy.
 Not heard anything yet but if it is not sorted I will be asking to see a manager to get a refund and get somewhere else to sort it out properly.
 Not too happy that they denied it could of been wrong straight away without even looking at the car
 ....Those words don't exactly inspire confidence or trust in that garage. I thought you said you trusted them.
 Do you know what sort of alignment rig Overton use? Hopefully either a Hunter Laser Rig or Beissbarth rig. They should not have completed the job and charged you while the ball joint issue was present.
				Sorry it was the place that done the alinment that I dropped the car back off to today.
 The garage that done the ball joint just told me that they should not of touched the ball joint nuts to adjust the camber as the cars front camber cannot be adjusted
				They sound like a proper bunch of cowboys.  :confused:
				Past couple of times I've used GT tyres in Forres for my 4 wheel alignment. Might be too far for you tho. Apparently the Golf can be adjusted 3 ways they charge for each adjustment. Last time I was around the £90 mark.
 Clark's Motorsport in Kintore are meant t be good aswell. Was it them you couldn't get a hold of for 4 weeks?
				Yeah it was Clarke Motorsport that was booked up.
 In hindsight I would of been better off just getting the wheel alinement done at Kwick fit etc and waiting to get I to Clarke Motorsport.
 I got my car back it is slightly better ( they said it needed a few small adjuatments) but just doesn't feel as good as it did.
 Going to phone them in the morning to see if I can get hold of a manager or supervisor to explain my experience with them and see if they offer some sort of refund
