All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: jollybob on September 26, 2012, 08:08:32 am
Title: vw mk5 golf code (V163)
Post by: jollybob on September 26, 2012, 08:08:32 am
 Hi, can anyone help me please, I have just fitted a vw reversing badge camera it is working fine but when I did a scan of my car it come up with the following faults,
Address 62: Door, Rear Left        Labels: None
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1302
   Coding: 0000144
   Shop #: WSC 00711 210 1012557
   VCID: 3874346432D5
2 Faults Found:
00098 - Left Rear Central Locking (Safe) Motor (V163)
            012 - Electrical Fault in Circuit
00930 - Locking Module for Central Locking; Rear Left (F222)
            008 - Implausible Signal – Intermitten
What can I do to clear these faults thanks Im new to this thanks?
Title: Re: vw mk5 golf code (V163)
Post by: Matto on September 26, 2012, 04:15:43 pm
Did you scan before you fitted the camera? I would say these were already stored and are not related. I had exactly the same faults (intermittently) for a while before the door lock module started to play up. Required a new module in the end.
To clear them you should be able to go into Address 62, Door Rear Left, then fault codes and then clear codes. They will probably clear but will reappear once the doors are locked/unlocked a few times.
Post by: Eddie-NL on September 26, 2012, 04:18:28 pm
the fault has nothing to do with the camera
either your lock is faulty or the wiring is damaged.
even if everything works, water damage to the wiring would be a possible cause
Post by: jollybob on September 27, 2012, 12:22:30 am
Thanks for your replies, I do have a lock with the same part number on will try fitting it tomorrow to see if I can get rid of the faults, will the faults everything is still working but just need rid of the faults.
Post by: jollybob on September 27, 2012, 04:22:40 pm
I would like to thank Eddie-NL and Matto for their help and support in sorting my fault codes out, I have no fault codes when I do a scan now, ended up needing new lock.
Post by: Matto on September 27, 2012, 05:18:09 pm
Glad you got it sorted  :happy2:
