All Things Mk5 => Mk5 General Area => Topic started by: AnilS on September 28, 2012, 02:04:36 pm
Title: Castrol Edge 5W/40 Fully Synthetic Oil
Post by: AnilS on September 28, 2012, 02:04:36 pm
As the same here;
http://www.amazon.co.uk/Castrol-Edge-5W ... B004AF34B8
For £6.99 in Home Bargains!
Was out having the Mercedes being attended to when I wondered into the Cape Hill branch (Birmingham). Cheap and handy for top ups.  :happy2:
Title: Re: Castrol Edge 5W/40 Fully Synthetic Oil
Post by: Jussa on September 28, 2012, 02:08:12 pm
Shocking, considering I had to buy an emergency 1 litre bottle the other day from a garage and it cost me £18.99  :fighting:
Post by: gazbutS3 on September 28, 2012, 03:02:01 pm
wrong grade for petrol cars though :happy2:
Post by: rich83 on September 28, 2012, 03:20:08 pm
Explain...?
Post by: gazbutS3 on September 28, 2012, 03:22:39 pm
Explain...?
as you ask so nicely  :smiley:
I'm pretty sure the recommended grade for the petrol cars is 5w30
Post by: Tfsi_Mike on September 28, 2012, 03:23:20 pm
I've been running 5w 40 on recommendation
Post by: gazbutS3 on September 28, 2012, 03:31:39 pm
my understanding is that a 40 grade oil will be thicker at 100 degrees than a 30, is this a good or bad thing? I don't know :laugh:
Post by: rich83 on September 28, 2012, 03:38:32 pm
Yeah thats right. In theory its better for engines which run quite hot, ie the TFSI.  :happy2:
(sorry for my blunt post... wasnt mean to come across like that  :drinking: )
Post by: gazbutS3 on September 28, 2012, 03:42:57 pm
I was under the impression the TFSI needed a thinner oil, maybe using a thicker oil when hot reduces the oil consumption, they can like a drink  :laugh:
Post by: rich83 on September 28, 2012, 03:44:39 pm
Well... my car is in for a service on monday and ill get Alex to check the oil level, ive not put a drop in mine since the last service 10,000 miles ago. :smiley:
Post by: Tfsi_Mike on September 28, 2012, 03:45:50 pm
Having the fancy millers Rich?
Post by: rich83 on September 28, 2012, 03:48:25 pm
Yes, I think its a wise move to use the best oil you can.  :happy2:
Post by: gazbutS3 on September 28, 2012, 03:49:04 pm
Its funny, some do some don't. My first GTI would use a fair bit, but the ED30 and S3 which both I got new did/have never used any oil. Could be down to the running in procedure???? or lack of it
Post by: homesqueeze on September 28, 2012, 03:55:05 pm
I saw somebody on here nicely explain it the other day. They said something along the lines of, if you drive like Miss Daisy you'll hardly use any oil, but if you drive like a hooligan it will absolutely slurp it down!
Post by: rich83 on September 28, 2012, 04:09:04 pm
Well... i do a lot of motorway miles, but it does get 'used'  :driver:
Post by: graeme on September 28, 2012, 04:45:04 pm
I have just recently got Silkolene PRO S 5W-40 ester synthetic oil for high performance engines. never tryed it before but was a decent price and with 20% off eveything at opieoils thought i might aswell try it .
as richwig83  says a thicker oil on a high preformance car will heat the oil up more ... thining it down to 5w30 in essence.  :happy2:
Post by: rich83 on September 28, 2012, 05:02:24 pm
Not quite. The engine oil should be the same temperature but at running temp. the 5w40 will remain thicker than 5w30.
Post by: graeme on September 28, 2012, 05:15:02 pm
ok maybe not worded so great but im sure you got the just of what i ment  :happy2:
Post by: gazbutS3 on September 28, 2012, 06:04:59 pm
not sure about that pal, I've done numerous 1/4's, 6 trackdays, you get the picture and it still uses very,very little. I just think some do, some don't  :happy2:
Post by: homesqueeze on September 28, 2012, 06:31:49 pm
Fair enough, you're probably right, I just liked the wording they used  :laugh:
Mines never used much oil really and over the years it's been driven both hard and gently
Post by: andygo on September 28, 2012, 06:56:02 pm
I have had several brand new cars over the years - Golf GTi 16v, Cosworths, Scooby sti's, Honda type R's, lotus Elise etc. I never ran them in for more than 100 miles and none of them used an appreciable amount of oil.
A pal of mines Nissan saloon thing is driven like miss daisy on a fuel economy run and uses a liter every 1200 miles. Must be like a 2 stroke!
Post by: stealthwolf on September 28, 2012, 08:45:40 pm
Alex recommended the 5W-40 for mapped engines which work harder than VW standards and hence would benefit from a different oil. If the car is standard, then 5W-30 is fine.
Post by: MPS on October 14, 2012, 02:49:51 pm
I have 5w30 edge professional in mine. Will the 5w40 be OK just for topping up with?
Post by: Poverty on October 14, 2012, 02:56:02 pm
poorly run in engines/piston rings will use alot of oil!
Post by: Luka on October 14, 2012, 04:28:25 pm
Stick to like for like grades when topping up oil.
Post by: R32UK on October 14, 2012, 05:20:30 pm
mine uses a ltr every 1000miles or so  :ashamed:
